Hi Alex, I confirmed the IO on the EC300 and it is correct. So there is a slight difference between the NVEM and EC300. I have updated the source and created individual firmware versions for the NVEM and EC300. Can you please test the NVEM version?Hi Scott
Could I get you to check this
I am running an NVEM RT-1052, when I activate remora.output.00 OUT-2 comes on.
And vice versa. remora.output.01 turns OUT-1.
This seems to be backwards. Is this whats intended?
Alex
Not to throw a spanner in the works. I I have an ST clone that I have not flashed and I got it to upload the firmware to the EC500 RT-1052. I used pyocd on linux (Buster)Unfortunaly i have only an stlink v2 at home
I literally tried this today without success (on Windows). pyOCD first complained about the old firmware version. I did a firmware upgrade to the minimum version number supported, pyOCD would not connect to the ST-link, upgrading to the latest firmware had the same result.
Worth a try if you only have one ST, let us know if it works for you also.
Cheers.
