2 years 9 months ago #289843 by TimGow
Looks like you have successfully programmed the board. Best to have Ethernet connected as the boot process will hang waiting for the network. Without the network cable attached I could reproduce what you are seeing with no serial output and the 3 LEDs on. But most often getting to
Remora RT1052 starting
Initializing PHY...
Scott, thank you for interpreting the pyocd output and LEDs ... onto the RPi4 now.
All the work much appreciated.
2 years 9 months ago #289857 by beauxnez
I soldered the wires on the nvem V5
is the wiring good I don't want them all to be burnt
2 years 9 months ago #289880 by TimGow
Hi beauxnez,
I'm guessing that you are needing to know any difference between NVEM V2 and V5.
NVEM V2 SWD connection is shown here:   15 Jan 2022 03:42 #231852
I see that your V5 has an additional underside component or solder joint inboard from your green wire connection, so there are differences and reason to verify the order of the SWDIO, SWCLK & GND.
2 years 9 months ago - 2 years 9 months ago #289904 by beauxnez
I just have the SWDIO, SWCLK and GND to connect to the SWDIO, SWCLK and GND of the programming key?
no 5v or 3.3v?
out of the 150 pages is there one that explains the procedure for flashing? a v5 version, v2 looks simpler flashed
Last edit: 2 years 9 months ago by beauxnez.
2 years 9 months ago #289909 by TimGow
beauxnez, you have checked Scott's YT videos?
2 years 9 months ago #289916 by cakeslob
Question to the other users, is everyone getting a following error on startup with the new firmware, like user freyja is experiencing?
Time to create page: 0.361 seconds
