2 years 9 months ago #290258 by scotta
Hi Scott,I have received an EC500, I flashed it with the 3.1.2.bin using Pyocd it looks like a success on boot up it has lit up 8 LEDs on the io output port see pictures and I received a lot of garbled data on the serial terminal but it might be my settings in real term I can ping the Ec500 and when I toggle emergency stop on LCNC the connect led lights up on EC500 yet to upload my configuration. I am not sure if it is all correct due to LEDs and serial output, are the LEDs meant to light up like this?Warren
Hi Warren, looks like some good success. Those lights being lit up on the outputs in due to the default config not configuring those. Once you upload a full config file they will be properly available.
2 years 9 months ago #290493 by raf1110
Hi
I am bit confused if file LinuxCNC/nvem-rt1052.txt is correct for NVEM rt1052 eth.
In file it states board: EC300.
Is this correct or shoud be board:NVEM?
2 years 9 months ago #290519 by rbobey1989
Hello everybody, well I can finally say that I received the encoder board from JLCPCB, the shipment took about 10 days, I leave here the link to my repository of the schematic and PCB design files for those who want to use or modify them, they are made with EasyEda, This board helps me keep the cable chaos I had before under control, As soon as I have some time I will prepare an image with the points where to place the jumpers on the EC500 and EC300 boards, greetings
The following user(s) said Thank You: scotta, Murphy
2 years 9 months ago #290526 by scotta
Thanks for highlighting the error. I've just corrected it. The board type is only used when loading the hardware encoder module.
2 years 9 months ago #290527 by scotta
Looking great. There's a group of Ozzie guys working on a custom RT1052 based controller board, running Remora of course. Hope they see this and adapt your interface into the design.
2 years 9 months ago #290532 by rbobey1989
Hi Scott, I still want to improve the QDC module a little more, incorporate the accumulator mode for single channel encoders, the problem has been time hehehe, if these guys need any help I would be happy to help them, greetings
Time to create page: 0.692 seconds
