2 years 9 months ago #290708 by cakeslob
Sorry, I must have misunderstood. So you have the RT1052 but you loaded the stm32 json?
Im not firmiliar with the RT1052 version, but if its like the stm32 version, you probably need to do some kind of fullchip erase, but I dont know very much about the rt1052
For installing linuxcnc RPI image refere here. it is premade with linuxcnc installed.
remora-docs.readthedocs.io/en/latest/sof...ry-pi-linuxcnc-image
do this for installing Rpi linuxcnc, the other section is old and no longer used.
"Deprecated instructions preserved for posterity"
after you have a linuxcnc install working, you need to install the component depending on which board you are running
remora-docs.readthedocs.io/en/latest/sof...mp-installation.html
then you need to configure your ethernet ip
remora-docs.readthedocs.io/en/latest/sof...hernet-software.html
2 years 9 months ago - 2 years 9 months ago #290731 by wazza77
Hi need a little bit of assistance with my setup I'm just trying to test things right now, I have programmed my ec500 and can ping and also connect with Linuxcnc I have successfully fully uploaded my configuration but I am getting stuck with a (joint 0 following error) I am using the ec500-rt1052-DMA.txt and remora-ec500.HAL and .INI from the github.com/scottalford75/Remora-RT1052-c...CNC/remora-ec500-DMA folder and my joint velocity is higher than TRAJ max velocity as it is in the repository.
When I go to jog an Axis I get no movement but my Velocity jumps to 1248.0 and I get the joint following error
Any thoughts would be appreciated.
I think I might have resolved this or just found a different issue
Warren
Last edit: 2 years 9 months ago by wazza77.
2 years 9 months ago #290738 by TimGow
I believe all names should match name with chip,board from start:
xxx.bin to xxx JSON config.txt that you upload. Folders with correct files and compiled halcomponent according to board in linuxcnc machine folders.
remora-nv is for NVEM not ECxxx series.
Make sure you use correct repo files correct for your board version/model
raf1110, thank you
2 years 9 months ago #290739 by TimGow
"remora-nv is for the stm32 versions"
"remora eth 3.0 is for the RT1052 versions"
cakeslob, thank you
2 years 9 months ago #290756 by raf1110
Now I need to know how this can be done.
I hope someone will shed some light on how this can be fixed.
This will be last puzzle I hope.
2 years 9 months ago #290778 by TimGow
raf1110,
I followed a link back somewhere in the 150+ pages showing how to install Debian Bookworm for RPi4; I'll try to find a 'link to that link'.
Time to create page: 0.937 seconds
