2 years 9 months ago #291009 by aol
have tried to install tftpy but not working...
cnc@raspberrypi:~$ pip install tftpy
bash: pip: command not found
cnc@raspberrypi:~$ sudo pip3 install tftpy
sudo: pip3: command not found
please help
2 years 9 months ago #291014 by dinamik
Can someone post or upload a complete manual for linuxcnc+remora+bob+rpi
Required hardware:
Models and versions of controllers and their characteristics
Models and versions of supported RPI with best latency
Hardware for flashing
Other hardware for communication ie. for encoders and other stuf..
Required software & OS:
Linux distro and version for RPi
Linuxcnc and version
Flashing tools
Flashing files---with links for all BoB models
Other files....
Tutorial for wiring, instaling, flashing, cofiguration & everything else needed...
Thanks in advance
2 years 9 months ago - 2 years 9 months ago #291040 by wazza77
Last edit: 2 years 9 months ago by wazza77. Reason: doubble post
2 years 9 months ago #291041 by wazza77
Required hardware:
Flashing tools
Other files....
Thanks in advance
This Project is still a work in progress the best place to start is Hear: remora-docs.readthedocs.io/en/latest/intro/intro.html wiring as per the instructions for EC300/500 etc, with the exception that you configure the outputs via config.txt file.
if you get stuck read this forum again even if you have read it front to back. try and figure things out (play around) and if truly stuck ask questions, answers will come they may take a while but they will come
good luck
Warren
2 years 9 months ago #291058 by tommylight
@wazza77
Please do not change the subject title.
Thank you.
ASUS ROG Crosshair VIII Impact - AMD X570
The following user(s) said Thank You: wazza77
2 years 9 months ago #291087 by wazza77
Sorry about that it was about 2 or 3am
Time to create page: 0.851 seconds
