Hi
I got stuck on serial output:
Remora RT1052 starting
Initializing PHY...
## Entering SETUP state
1. Loading JSON configuration file from Flash memory
Flash storage location is empty - no config file
Using basic default configuration - 3 step generators only
2. Parsing JSON configuration file
Config deserialisation - Deserialization succeeded
3. Configuring threads
Creating thread 40000
Creating thread 1000
4. Loading modules
Creating a std module
Creating an Ethernet communication monitoring module
Creating Pin @
port = GPIO3
pin = 0
Base thread object
X - Joint 0 step generator
Creating Pin @
port = GPIO1
pin = 22
Creating Pin @
port = GPIO1
pin = 17
Base thread object
Y - Joint 1 step generator
Creating Pin @
port = GPIO1
pin = 24
Creating Pin @
port = GPIO1
pin = 31
Base thread object
Z - Joint 2 step generator
Creating Pin @
port = GPIO1
pin = 18
Creating Pin @
port = GPIO1
pin = 25
X_Limit
Make Digital Input at pin P4_26
Creating Pin @
port = GPIO4
pin = 26
Y_Limit
Make Digital Input at pin P4_27
Creating Pin @
port = GPIO4
pin = 27
Z_Limit
Make Digital Input at pin P4_21
Creating Pin @
port = GPIO4
pin = 21
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 100
configuring Timer 1
timer started
Starting the SERVO thread
Registering interrupt for interrupt number = 101
configuring Timer 2
timer started
## Entering IDLE state
I have one stepper connected to X axis output and now I am not sure how to setup machine on EMC2 to have clearly control from UI screen.
Pin 21 seem to be X-in and port 4 is Estop I think.
I have uploaded standard config that is on git fro NVEM v5 rt chip.
Is it possible to use wizard to create setup file?
