- Thank you received: 135
- royka
4 years 6 months ago - 4 years 6 months ago #241721
by royka
Edit: didn't see the pictures, but still isn't it t a problem with the board/firmware. For the following error you could set the velocity of the joint higher then the axis velocity. Scotta explained that already to me in this topic, however I still had the following errors. The parameter errors I don't know. As far as I can see it's nothing from the ini or hal, perhaps in one of the other linked files "toplevel.py, one of the probescreen files, etc...", but better to ask these questions in the right section
Replied by royka on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
This is nvem2 topic indeed. the problems you mention has nothing to do with the nemv2 board/firmware. As Scotta already told you there are other sections on this forum for these questions. In my ini file you won't find anything about the spindle, this information needs te be in your hal file, this info I've already posted. The max limit is the soft limit you set in the ini file under the axis and joints, but again this has nothind to do with the nvem2. It would be nice if you could keep this topic clean, so when people want to find info about Scotta his firmware for this board they could find it easily.???? This is an NVEM V2 board. Can someone please help with my problem? In fact, anyone who goes the route will need it. What I'm very grateful to Scott for. If I have everything done and functional then I will be happy to share the files for everyone. I'm beginning to understand paths and lines. But not yet at 100 percent. well thank you
Last edit: 4 years 6 months ago by royka.
- scotta
- Thank you received: 489
4 years 6 months ago #241745
by scotta
Domi,
For [AXIS_2] MAX_LIMIT is not defined, this looks to be because of an old version probe_screen.py
forum.linuxcnc.org/gmoccapy/36973-error-...be-screen-v2?start=0
I'm guessing the _hal error is also due to an old probe screen of gladevcp using axis numbers rather than letters. Best to ask for help in those sections of the forum.
The following user(s) said Thank You: Domi
- scotta
4 years 6 months ago #241746
by scotta
Roy, FYI I'm still looking at the following errors. Something really strange going on somewhere as the errors are consistently the same magnitude. I could test by increasing the max following error so that the program would keep running. The same magnitude following error spike on different joints. Makes me think it's something to do with DDS accumulator over flow that Rafal observed in the other thread. Anyway, Thanks for your help and patience.
The following user(s) said Thank You: royka, spdbmp927
- royka
4 years 6 months ago #241790
by royka
Good to know that you've recognized the problem. I'm not a programmer or whatsover so maybe it's nonsense. But I was thinking, could it be an config error so it uses the internal oscillator? As the internal one is unstable according this site: www.jaybee.cz/software/stm32-hse-oscillator-stability-problem/ . Or as I've read some more problems about this board with the original firmware, maybe the external one being unstable? Because of a bad pcb design as seen on this site?: community.st.com/s/question/0D53W00001IB...-internal-oscillatorRoy, FYI I'm still looking at the following errors. Something really strange going on somewhere as the errors are consistently the same magnitude. I could test by increasing the max following error so that the program would keep running. The same magnitude following error spike on different joints. Makes me think it's something to do with DDS accumulator over flow that Rafal observed in the other thread. Anyway, Thanks for your help and patience.
- fupeama
- Thank you received: 14
4 years 6 months ago #241804
by fupeama
Replied by fupeama on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
HI,
Can I ask for help?
I have 3axis nvem v2 card.
I am able....
Compile firmware in stm32cubeide.
Upload (compiled or downloaded ) firmware to card through st-link v2.
upload config.txt to storage space in card. rs232 say, that all is ok.
compile and install remora-eth.c
ping to card 10.10.10.10, ok
But... I cannot connect to card. Linuxcnc start independently on ip adress.
I try to changed ip for example to 10.10.10.11 or 192.168.1.1. in remora-eth.c. or disconnect card. result is same. linuxcnc start, I can see remora joint 0-7 but cmd feedback is death. following error on all joints.
there is some debug information on serial port or on linux when card is connect? I finished in IDLE state.
Thanks for hint
Martin
Can I ask for help?
I am able....
Thanks for hint
Martin
- royka
4 years 5 months ago #241806
by royka
On the serial monitor you should see it's loading the whole configuration, like this log:
## Entering SETUP state
1. Loading JSON configuration file from Flash memory
2. Parsing JSON configuration file
Config deserialisation - Deserialization succeeded
3. Configuring threads
Creating thread 40000
Creating thread 1000
4. Loading modules
Creating a std module
Creating an Ethernet communication monitoring module
Base thread object
X - Joint 0 step generator
Creating Pin @
port = GPIOE
pin = 15
Creating Pin @
port = GPIOE
pin = 14
Base thread object
Y - Joint 1 step generator
Creating Pin @
port = GPIOE
pin = 13
Creating Pin @
port = GPIOE
pin = 12
Base thread object
Z - Joint 2 step generator
Creating Pin @
port = GPIOE
pin = 11
Creating Pin @
port = GPIOE
pin = 10
FHA
Make Digital Input at pin PD_12
Setting pin as No Pull
Creating Pin @
port = GPIOD
pin = 12
FHB
Make Digital Input at pin PD_13
Creating Pin @
port = GPIOD
pin = 13
SRO
Make Digital Input at pin PB_14
Creating Pin @
port = GPIOB
pin = 14
SJR
Make Digital Input at pin PB_15
Creating Pin @
port = GPIOB
pin = 15
STOP
Make Digital Input at pin PD_8
Creating Pin @
port = GPIOD
pin = 8
PROBE
Make Digital Input at pin PD_9
Creating Pin @
port = GPIOD
pin = 9
INP3
Make Digital Input at pin PD_10
Creating Pin @
port = GPIOD
pin = 10
INP4
Make Digital Input at pin PD_11
Creating Pin @
port = GPIOD
pin = 11
INP5
Make Digital Input at pin PD_14
Creating Pin @
port = GPIOD
pin = 14
INP6
Make Digital Input at pin PD_15
Creating Pin @
port = GPIOD
pin = 15
INP7
Make Digital Input at pin PC_6
Creating Pin @
port = GPIOC
pin = 6
INP8
Make Digital Input at pin PC_7
Creating Pin @
port = GPIOC
pin = 7
INP9
Make Digital Input at pin PC_8
Creating Pin @
port = GPIOC
pin = 8
INP10
Make Digital Input at pin PC_9
Creating Pin @
port = GPIOC
pin = 9
INP11
Make Digital Input at pin PA_11
Creating Pin @
port = GPIOA
pin = 11
INP12
Make Digital Input at pin PA_12
Creating Pin @
port = GPIOA
pin = 12
INDEX
Make Digital Input at pin PC_15
Creating Pin @
port = GPIOC
pin = 15
x100
Make Digital Input at pin PA_15
Creating Pin @
port = GPIOA
pin = 15
x10
Make Digital Input at pin PC_10
Creating Pin @
port = GPIOC
pin = 10
x1
Make Digital Input at pin PC_11
Creating Pin @
port = GPIOC
pin = 11
ESTOP
Make Digital Input at pin PC_12
Creating Pin @
port = GPIOC
pin = 12
Xin
Make Digital Input at pin PD_7
Creating Pin @
port = GPIOD
pin = 7
Yin
Make Digital Input at pin PD_4
Creating Pin @
port = GPIOD
pin = 4
Zin
Make Digital Input at pin PD_3
Creating Pin @
port = GPIOD
pin = 3
Ain
Make Digital Input at pin PD_2
Creating Pin @
port = GPIOD
pin = 2
Bin
Creating Pin @
port = GPIOD
pin = 1
Cin
Make Digital Input at pin PD_0
Creating Pin @
port = GPIOD
pin = 0
WHA
Make Digital Input at pin PB_7
Creating Pin @
port = GPIOB
pin = 7
WHB
Make Digital Input at pin PB_6
Creating Pin @
port = GPIOB
pin = 6
OUT1
Make Digital Output at pin PC_3
Creating Pin @
port = GPIOC
pin = 3
OUT2
Make Digital Output at pin PC_2
Creating Pin @
port = GPIOC
pin = 2
OUT3
Make Digital Output at pin PB_8
Creating Pin @
port = GPIOB
pin = 8
OUT4
Make Digital Output at pin PB_9
Creating Pin @
port = GPIOB
pin = 9
OUT5
Make Digital Output at pin PE_0
Creating Pin @
port = GPIOE
pin = 0
OUT6
Make Digital Output at pin PE_1
Creating Pin @
port = GPIOE
pin = 1
OUT7
Make Digital Output at pin PE_2
Creating Pin @
port = GPIOE
pin = 2
OUT8
Make Digital Output at pin PE_3
Creating Pin @
port = GPIOE
pin = 3
OUT9
Make Digital Output at pin PC_13
Creating Pin @
port = GPIOC
pin = 13
OUT10
Make Digital Output at pin PC_14
Creating Pin @
port = GPIOC
pin = 14
Spindle PWM
NVMPG
Registering interrupt for interrupt number = 58
Creating NVMPG module
UART1 DMA configured
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 25
power on Timer 1
timer started
Starting the SERVO thread
Registering interrupt for interrupt number = 28
power on Timer 2
timer started
## Entering IDLE state
Time to create page: 1.140 seconds
