- Thank you received: 489
- scotta
4 years 6 months ago #241122
by scotta
The following user(s) said Thank You: Domi
- eng
- Thank you received: 8
4 years 6 months ago #241411
by eng
Replied by eng on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Take a doubt, forgive me in advance if I'm asking a nonsense, because I'm learning all this about programming, I'm testing the esp32 with linux which by the way works very well, there we use the arduino ide to write the firmware, I wanted to know if here with the remora, it would be possible to use the arduino ide too or would that not be possible? I won a nvem to start my studies, I'm waiting for it to arrive to start the tests.
- Domi
4 years 6 months ago #241619
by Domi
Replied by Domi on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello. I ran almost everything. Air for probe touch sensor and so on. The spindle failed. Royka: Wouldn't you provide your file ini? And I have another problem that I can't solve. still has joint2 and max limit error. I've tried everything but I can't handle it. I send photos and files of halls and others. Thank you in advance for the advice.
- Domi
4 years 6 months ago #241621
by Domi
I'm sorry. I don't know why it took more times.
- scotta
4 years 6 months ago #241688
by scotta
It may be possible using stm32duino ( github.com/stm32duino/Arduino_Core_STM32 ) which is based on STM32Cube, so the same HAL layer.Take a doubt, forgive me in advance if I'm asking a nonsense, because I'm learning all this about programming, I'm testing the esp32 with linux which by the way works very well, there we use the arduino ide to write the firmware, I wanted to know if here with the remora, it would be possible to use the arduino ide too or would that not be possible? I won a nvem to start my studies, I'm waiting for it to arrive to start the tests.
- Domi
4 years 6 months ago #241713
by Domi
???? This is an NVEM V2 board. Can someone please help with my problem? In fact, anyone who goes the route will need it. What I'm very grateful to Scott for. If I have everything done and functional then I will be happy to share the files for everyone. I'm beginning to understand paths and lines. But not yet at 100 percent. well thank you
Time to create page: 1.155 seconds
