4 years 6 months ago #240955 by Domi
I'm responding to the fact that Scott has cut the functions of the halls. No mom stuck too sure. Therefore, I am asking to re-install eth.h and c. But the result is probably the same. Although, if I understood correctly, I can use an axis that suits me and add lines or search for a dysplay that is suitable for me and also adjust the inputs and outputs. Is that so? I just need to add V2 to the probe screen to make a blast before the measurement. What is understandable relay output at a certain time and still cooling outputs. Mist a flood. I just don't know how to make a blast in probe screen v2 before measuring the instrument
4 years 6 months ago #240956 by Domi
Share the configuration of Hal and especially if you need it about me. Well thank you
4 years 6 months ago - 4 years 6 months ago #240957 by Domi
Scotta : yes. I did all this
Last edit: 4 years 6 months ago by Domi.
4 years 6 months ago - 4 years 6 months ago #240958 by Domi
To be clear: I want to use this tool sensor + 3d touch + cooling mist, flood and air. And I have no idea how to use all this in Axis and realtime.
The offset would be used as I have used it so far.3D touch sensor + tool sensor probe screen V2. I will be grateful for help
4 years 6 months ago - 4 years 6 months ago #240960 by scotta
Hi Domi,
You will have a very nice setup once completed, but a little off topic for this thread. Maybe ask for some assistance in the Advanced Configuration section of the forum. Unfortunately I have not even tried to configure some of these functionality in LinuxCNC myself. Sorry.
The configuration for these is nearly identical to that for a Mesa card, just different naming of the IO etc.
Last edit: 4 years 6 months ago by scotta.
4 years 6 months ago #241097 by Domi
Does anyone have at least a spindle configured? Well thank you
Time to create page: 1.108 seconds
