  • Moderator
  • Moderator
1 year 6 months ago #326700 by tommylight
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
No worries, you are welcomed here always.
The following user(s) said Thank You: DarkPhoinix
1 year 6 months ago #326701 by DarkPhoinix
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thank you, very kind of you.
1 year 6 months ago - 1 year 6 months ago #326707 by DarkPhoinix
I managed to install remora by chance, I'm not so happy about this I would like to understand what I did wrong before:
Are MCUXpresso and the sdk for rt1050 necessary for pyocd?
Thanks to all people for the work of this project LinuxCNC and Remora!
Last edit: 1 year 6 months ago by DarkPhoinix.
1 year 6 months ago - 1 year 6 months ago #326710 by DarkPhoinix
In the manual it says: git clone github.com/scottalford75/Remora
is that correct?
or I have to do:  git clone github.com/scottalford75/Remora-RT1052-cpp
remora-docs.readthedocs.io/en/latest/sof...mp-installation.html
I went a bit by instinct and installed this:
github.com/scottalford75/Remora-RT1052-c.../remora-rt1052-basic
linuxcnc gives me this error:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.9.4 Machine configuration directory is '/home/cnc/linuxcnc/configs/remora-rt1052-basic' Machine configuration file is 'remora-ec500.ini' INIFILE=/home/cnc/linuxcnc/configs/remora-rt1052-basic/remora-ec500.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TPMOD= HOMEMOD= TASK=milltask HALUI=halui DISPLAY=axis COORDINATES=X Y Z KINEMATICS=trivkins coordinates=XYZ Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Found file(REL): ./remora-ec500.hal Found file(REL): ./remora-nv-mpg.hal Shutting down and cleaning up LinuxCNC... Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime nvmpg: dlopen: /usr/lib/linuxcnc/modules/nvmpg.so: cannot open shared object file: No such file or directory ./remora-nv-mpg.hal:6: waitpid failed /usr/bin/rtapi_app nvmpg ./remora-nv-mpg.hal:6: /usr/bin/rtapi_app exited without becoming ready ./remora-nv-mpg.hal:6: insmod for nvmpg failed, returned -1 3286 Stopping realtime threads Unloading hal components Note: Using POSIX realtime ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file:    /tmp/linuxcnc_info.txt can be posted to a forum or a web site like:      http://pastebin.com in order to provide information about the linuxcnc system and configuration.                 Date: sab 19 apr 2025, 16:46:59, CEST             UTC Date: sab 19 apr 2025, 14:46:59, UTC         this program: /usr/bin/linuxcnc_info               uptime: 16:46:59 up 12 min, 1 user, load average: 1,33, 1,38, 0,81      lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm             linuxcnc: /usr/bin/linuxcnc                  pwd: /home/cnc/linuxcnc/configs/remora-rt1052-basic                 USER: cnc              LOGNAME: cnc                 HOME: /home/cnc               EDITOR:                VISUAL:              LANGUAGE:                  TERM: dumb            COLORTERM:               DISPLAY: :0.0              DESKTOP: lightdm-xsession         display size: 1920x1200 pixels (508x317 millimeters)                 PATH: /usr/bin:/home/cnc/linuxcnc/configs/remora-rt1052-basic/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games uname items:          nodename -n: cnc       kernel-name -s: Linux       kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.1.133-1 (2025-04-10)           machine -m: x86_64         processor -p: unknown          platform -i: unknown       oper system -o: GNU/Linux /proc items:              cmdline: BOOT_IMAGE=/boot/vmlinuz-6.1.0-33-rt-amd64 root=UUID=e5282ae9-3e96-4f4e-9c6c-19b3dd421c80 ro initrd=/install/gtk/initrd.gz quiet           model name: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz                cores: 4              cpu MHz: 3425.725              parport: 0000-0000 : parport0 0000-0000 : parport0               serial: 0000-0000 : serial Versions:                  gcc: gcc (Debian 12.2.0-14) 12.2.0               python: Python 3.11.2                  git: git version 2.39.5           git commit: NA                  tcl: 8.6                   tk: 8.6                glade: not_in_PATH linuxcnc_var all:      LINUXCNCVERSION: 2.9.4 LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples             REALTIME: /usr/lib/linuxcnc/realtime                  RTS: uspace           HALLIB_DIR: /usr/share/linuxcnc/hallib               PYTHON: /usr/bin/python3 dpkg -l '*linuxcnc*': Voluto=U (non noto)/I (installato)/R (rimosso)/P (rimosso totale)/H (in attesa) | Stato=Non/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(nessuno)/R (reinstallazione richiesta) (Stato,Err: maiuscolo=grave) ||/ Nome                Versione     Architettura Descrizione +++-===================-============-============-===================================================================== un  linuxcnc            <nessuna>    <nessuna>    (nessuna descrizione disponibile) un  linuxcnc-dev        <nessuna>    <nessuna>    (nessuna descrizione disponibile) un  linuxcnc-doc        <nessuna>    <nessuna>    (nessuna descrizione disponibile) ii  linuxcnc-doc-de     1:2.9.4      all          motion controller for CNC machines and robots (German documentation) ii  linuxcnc-doc-en     1:2.9.4      all          motion controller for CNC machines and robots (English documentation) ii  linuxcnc-doc-es     1:2.9.4      all          motion controller for CNC machines and robots (Spanish documentation) ii  linuxcnc-doc-fr     1:2.9.4      all          motion controller for CNC machines and robots (French documentation) un  linuxcnc-sim        <nessuna>    <nessuna>    (nessuna descrizione disponibile) un  linuxcnc-sim-dev    <nessuna>    <nessuna>    (nessuna descrizione disponibile) ii  linuxcnc-uspace     1:2.9.4      amd64        motion controller for CNC machines and robots ii  linuxcnc-uspace-dev 1:2.9.4      amd64        PC based motion controller for real-time Linux
1 year 6 months ago - 1 year 6 months ago #326717 by jjdege
Hi
i think you didn't install the NVMPG component here
Last edit: 1 year 6 months ago by jjdege.
1 year 6 months ago #326719 by DarkPhoinix
Hi
I thought it was optional.
Do I have to install all of these then?:
sudo halcompile --install ./Remora-eth/remora-eth-3.0.c
sudo halcompile --install ./Remora-spi/remora-spi.c
sudo halcompile --install ./Remora/remora_lpc.c
sudo halcompile --install ./NVMPG/nvmpg.c
sudo halcompile --install ./PIDcontroller/PIDcontroller.c
sudo halcompile --install ./PRUencoder/PRUencoder.c
I don't have a raspberry
Thank you so much for your precious help
Time to create page: 1.132 seconds
