- Thank you received: 38
- jjdege
1 year 6 months ago #326720
by jjdege
Replied by jjdege on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi
with the steps described in the various posts I have successfully installed Remora on a NVEM V5.
I have a problem, joint3 does not run, I have deleted and reloaded remora four times, without success, joint3 does not run.
Tried a five-axis gantry XYYZA configuration, the XYY axis works, A (joint4) works, Z axis (joint3) does not work
the configuration file is the one in the LinuxCNC folder
nvem-rt1052.txt join3 are "P1_27", "P1_21" ?
I have checked the entire configuration many times, maybe I am missing something
P.S. thanks again to Scott and everyone who made it all possible
- jjdege
1 year 6 months ago #326721
by jjdege
it is optional, but in your configuration in the.ini file you have called it
if you don't need it comment it and don't install the component
I thought it was optional.
HALFILE = remora-nv-mpg.hal
The following user(s) said Thank You: DarkPhoinix
- DarkPhoinix
- Thank you received: 6
1 year 6 months ago - 1 year 6 months ago #326722
by DarkPhoinix
work at 12V and 5v
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I wanted to thank you now I have the connection with nvem v5 and linuxcnc, I see it because using the software stop the red led lights up. Regarding your problem I have not yet received either DRIVERS or STEPER is there a way to test the outputs without having these components? like led? or I have this small steper but I would not like to damage the board by connecting it:Hi
work at 12V and 5v
Last edit: 1 year 6 months ago by DarkPhoinix.
- DarkPhoinix
1 year 6 months ago - 1 year 6 months ago #326726
by DarkPhoinix
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Z - Joint 2 step generator",
"Joint Number": 2,
"Step Pin": "P1_18",
"Direction Pin": "P1_25"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "A - Joint 3 step generator",
"Joint Number": 3,
"Step Pin": "P1_27",
"Direction Pin": "P1_21"
I have the same configuration loaded for my Z and A they are different
"Thread": "Base",
"Type": "Stepgen",
"Joint Number": 2,
"Thread": "Base",
"Type": "Stepgen",
"Joint Number": 3,
- Thank you received: 7491
1 year 6 months ago #326727
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
That drive and board require Quadrature outputs, LinuxCNC can do that easily, but i have no idea if Remora can do that.
There are 9 or 10 stepgen types that LinuxCNC can do, and probably 3 of those should work.
And just to be clear that "drive" is not a drive, it is an array of Darlington transistors that can handle 500mAh, if i recall correctly.
Apparently there are 15 types now, just checked so i need to update myself from 2008!
linuxcnc.org/docs/html/man/man9/stepgen.9.html
- DarkPhoinix
1 year 6 months ago #326735
by DarkPhoinix
Driver:TB6560 JP-1635A
Steper: 57hdd0401
In your opinion is it safe to connect this driver and stepper?
Can I use the same 24V power supply that I use to power NVEM or is it better to use a separate one?
I only need it to test the jjdege conf (if I'm not mistaken it's the same conf as mine then it will tell me nvem-rt1052.txt)
to check the outputs.
I will never use this driver-stepper as a final solution.
Steper: 57hdd0401
Time to create page: 0.325 seconds
