1 year 6 months ago #326907 by jjdege
Hi
the board is a 3-axis, but I don't think it depends on that, I think.
Ultimately, on six axes XYB working, Z and C turning in one direction, dir doesn't work, A doesn't work.
I haven't had any luck....
this is the second board, the first one in understanding how to flash it I must have made it unusable, I can't get it back.
I don't want to buy another one, never mind.
Thanks for the feedback
1 year 6 months ago - 1 year 6 months ago #326908 by DarkPhoinix
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi
try this:
mkdir ~/linuxcnc/configs/remora-rt1052-test
pair the contents in this dir:
github.com/scottalford75/Remora-RT1052-c.../remora-rt1052-basic
download this:  github.com/scottalford75/Remora-RT1052-c...xCNC/nvem-rt1052.txt
python3 upload_config.py nvem-rt1052.txt
pair your files:nvem-rt1052.hal,nvem-rt1052.ini
then:
and try again please
Last edit: 1 year 6 months ago by DarkPhoinix.
The following user(s) said Thank You: jjdege
1 year 6 months ago #326909 by DarkPhoinix
I try again and C turning in all direction.
1 year 6 months ago - 1 year 6 months ago #326935 by jjdege
Thank you
it's not a configuration problem
I tried the procedure you described, but nothing changes
XYB works, ZC dir doesn't work, A doesn't work
it's a hardware problem.
Last edit: 1 year 6 months ago by jjdege.
1 year 6 months ago - 1 year 6 months ago #326945 by DarkPhoinix
Thank you
www.ti.com/lit/ds/symlink/sn74alvc164245...2Fwww.mouser.kr%252F
can you desoldering and test this? or replacing it shouldn't cost too much.
1 year 6 months ago #326947 by jjdege
I guess the culprit is that chip, I already tried to redo the soldering, but it was no use.
I have the first unusable board with two of those chips, I'll see what I can do, I've never unsoldered/soldered chips like that.
thanks
Time to create page: 0.828 seconds
