1 year 6 months ago #327284 by Spyderbreath
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good day all. I seem to be having a bit to trouble getting started. I have an NVEM V5 controller and RPI 5 with LinuxCNC installed. Is there anywhere on planet earth that has a start to finish, all in one place, all on one page, set of instructions or video that will tell me what version of what software from what source to use in what way using what commands and what wires to hook up where to get it all done with the hardware I have. I have gone through 100's of posts and can grasp the general concepts of what needs to be done but it's a small and sometimes incomplete piece of info from 1 post and then one has to read 5 or 20 more before the rest of the info is found. In the end, and totally a flaw of my own, I seem unable to pull all of this scattered info together and have it make any sense as to how to get from start to finish without burning something up or creating an unsalvageable mess.
I found a video by Scott 3D on youtube but it is 3 years old and several key points are just blown by with no explanation and no info on exactly what versions of what from where is needed today.
Is there a single set of complete instructions with valid links in existence anywhere for setting up an NVEM v5 with LinuxCNC?
1 year 6 months ago #327288 by Daz
Hello, first, you need to get yourself a CMSIS-DAP probe. You can buy one on eBay, Amazon, or covert an ST-link probe. Here is a line to the thread how to do it.
forum.linuxcnc.org/18-computer/44828-rem...rd?start=2050#321860
Once you have the probe, you need to upload the firmware, I will send you the commands later when I have a moment to take a look into my notes.
Once you have the new firmware, then you can follow the instructions from my post above:
forum.linuxcnc.org/18-computer/44828-rem...rd?start=2140#327240
Happy to help
1 year 6 months ago #327301 by Spyderbreath
Thank you for the reply Daz, and the offer to help
I now have what appears to be a successfully flashed and converted ST to DAP-link.
Now I am at the point where I need to hook this newly converted DAP-link to the NVEM controller. Is there a wiring schematic somewhere or something that tells me which pads on the controller get which wires? The pads are not labeled on the controller.
1 year 6 months ago #327304 by cakeslob
@cakeslob , I had a look at your hal file again and copied your spindle stuff exactly just changed for my pins etc and it's still the same. So I think that rules out a hal file problem. I don't think it's the vfd because I can change the speed manually by pressing the + and - manually in the  Axis GUI and it responses quick with no dips when changing speeds.
Hmm probably going to have to do a halscope to see what is happening with that remora.sp0 and/or RPM signal when using css. The fact that it only does it while CSS is making this difficult to narrow down
just do a quick double check of my config ini/hal, and see if anything stands out. This is the config I used to test out threading and css the last time we talked. I dont think my halfile was a whole lot different, but maybe something in the ini file. Im still very new with lathe, but threading and css appear to function as intended.
github.com/cakeslob/RRW_LAB/tree/inc/Lin...mora-RRW_LAB_latheng
1 year 6 months ago #327307 by Attis92
Hello Daz,Could you please share the serial log during the config upload?
I'm curious about the CRC check.Thanks in advance!
1 year 6 months ago #327312 by Daz
Here is the CRC check for EC300:
Valid JSON config file, uploading to board
Config file length (words) = 1702
Config file length (bytes) = 6805
Remainder = 1
Padding added = [0, 0, 0]
Config file length with padding (bytes) = 6808
CRC-32 = 0x4731b6
Time to create page: 0.777 seconds
