- Thank you received: 323
Potential All-in-One Single Board Computers
- unknown
1 year 8 months ago #321494
by unknown
Replied by unknown on topic Potential All-in-One Single Board Computers
The older versions are suitable for ethercat, the latest versions have a kernel that ethercat doesn't support.
Also there are some very old 64 and 32 bit PC versions there as well.
The downloads page on the homepage points to the most recent versions.
- Thank you received: 4153
1 year 8 months ago #321535
Replied by rodw on topic Potential All-in-One Single Board Computers
That may have been resolved by the etherlabmaster guys by a recent commit on their repo. We install from their repo so any changes flow through via their Buildbot without further action other than an apt update if an existing install or reinstalling the image.The older versions are suitable for ethercat, the latest versions have a kernel that ethercat doesn't support.
- unknown
1 year 8 months ago #321609
by unknown
Ethercat appears to install ok, some modules are built for the current kernel, some are built for 6.1.0-31-arm64.
With no Ethercat devices connected I get this, would this indicate a good install ?
cnc@raspberrypi:~$ ethercat master
Master0
Phase: Idle
Active: no
Slaves: 0
Ethernet devices:
Main: d8:3a:dd:ac:2e:74 (attached)
Link: UP
Tx frames: 28884
Tx bytes: 1733040
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 124 124 122
Tx rate [KByte/s]: 7.3 7.3 7.1
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
Common:
Tx frames: 28884
Tx bytes: 1733040
Rx frames: 0
Rx bytes: 0
Lost frames: 28884
Loss rate [1/s]: 124 124 122
Frame loss [%]: 100.0 100.0 100.0
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000
1 year 8 months ago #321680
Yeh, that looks OK. If Ethercat was going to fail due to unsupported kernel, you would not have got that far...
- unknown
1 year 8 months ago #321683
by unknown
OK that's a good start, all we need is someone to confirm with actual hardware.
- 3404gerber
- Thank you received: 14
1 year 6 months ago #327132
by 3404gerber
Replied by 3404gerber on topic Potential All-in-One Single Board Computers
The
Radxa Zero 3E
is a nice small SBC very similar to the Pi Zero but available with more RAM and an ethernet connector. You don't want to use it for step generation, but with the latest Armbian running a 6.12 RT kernel, the latency is ok, especially for a headless motion controller running a servo-thread. Could be interesting for example in a OpenPNP setup. One problem is that USB is not working with current kernel, but this will probably be fixed soon.
Yesterday I ran a G1F1X100 command with 6 TMC5160 connected over SPI @ 6MHz and spidev driver; the servo-thread (reading all 6 position, writing all 6 speed, only one PID) stayed under 0.75 ms for the entire 100 minutes.
Time to create page: 0.279 seconds
