- Thank you received: 234
Potential All-in-One Single Board Computers
- Bari
3 years 1 month ago - 3 years 1 month ago #280883
by Bari
Replied by Bari on topic Potential All-in-One Single Board Computers
Yes, that is pretty much it.
LCNC can run on 1GB of RAM but things like the backplot in the GUI need more RAM so 2+GB keep it running smoothly and quickly.
Remora is also working over Ethernet.
There are also some low cost FPGA cards that work well over Ethernet.
forum.linuxcnc.org/27-driver-boards/4442...pga-controller-board
The RK3588 has been shown to run a base thread with low enough jitter for software stepping to ~66KHz.
forum.linuxcnc.org/18-computer/48079-can...cnc?start=250#274284
Last edit: 3 years 1 month ago by Bari.
- Thank you received: 4153
3 years 1 month ago #280897
Replied by rodw on topic Potential All-in-One Single Board Computers
We should not be using software stepping on these devices. We should use an interrupt driven timer thread to generate step pulses that can be controlled in the same way as a Mesa card. I've had a bit of look at it and its probably easier than you might first think.The RK3588 has been shown to run a base thread with low enough jitter for software stepping to ~66KHz.
- Gene1934
- Thank you received: 13
2 years 11 months ago #284580
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
Replied by Gene1934 on topic Potential All-in-One Single Board Computers
Another board we might want to look at, assuming an rpi4b approach to it, is the bananapi-m5, which has 4G of memory and a 4 core 2 gigahertz processor that runs kool enough it doesn't have to have a full complement of heat sinks stuck to it.
Around $80/copy, needs a psu, keyboard and mouse. Or just the psu if running it from some other machine on your local net.
I'm running several of them using the klipper firmware to drive 3d printers, running on current ambian.The video is supplied over the network by an nguinx server and I can run the printer from any machine on my local home net just by sending FF to machine alias:80 in the FF address line. I'd luv to be able to standardize all my stuff to this board. Or if you have keyboard and rodent, FF looking at localhost:80 gets control of it all.
Cheers all, Gene
Cheers all, Gene
- Bari
2 years 11 months ago #285835
by Bari
Banana pi BPI-M5
wiki.banana-pi.org/Banana_Pi_BPI-M5
- Gene1934
2 years 11 months ago #285839
by Gene1934
That 16Gb of emmc memory is not used by armbian jammy so I mount it & stash stuff I want to save over a system upgrade in it for ready access in case the upgrade goes south. With kiauh.sh in charge of the updates of everything including the armbian install, I've not ever needed it.
With an update to rpspi for the different gpio driver, I see no reason this board should not run LinuxCNC even better than an rpi4.
- Bari
2 years 11 months ago #286287
by Bari
Can the last 7-8 posts please go into a new thread about Mesa bus switches or similar. It going a bit off track for a list of SBC's compatible with LCNC.
Time to create page: 0.556 seconds
