16 Jan 2024 11:01 #290854 by meister
22 Jan 2024 18:11 #291354 by meister
Sorry,
old lathe converted to cnc with 3d printed parts.
nothing adjusted, rattles and wobbles ;)
BUT, G33 also works also on the rewrite branch:
22 Jan 2024 19:08 #291357 by tuxcnc
Where are configs?
23 Jan 2024 08:36 #291407 by meister
you can add something like this to your json config:
"type": "vin_quadencoderz",
"name": "spindle_encoder",
"pullup": true,
"function": "spindle-index",
"scale": 600.0,
"pins": {
"a": "86",
"b": "85",
"z": "84"
this will add this lines to the rio.hal:
setp rio.spindle_encoder-scale 600.0
net spindle-position rio.spindle_encoder => spindle.0.revs
net spindle-index-enable rio.spindle_encoder-index-enable <=> spindle.0.index-enable
The following user(s) said Thank You: tuxcnc
27 Jan 2024 10:54 #291739 by eduardo20
We develped the possibility to load a new bistream file into the Tangnao9k via browser while the Tangnano9k is connected via USB to your PC.
Let me know if you are interested in that.
27 Jan 2024 11:07 #291740 by eduardo20
We try to make it easy for people to build the firmware and generate a bitstream.
We currenlty offer some demo designs for different FPGA boards which you can generate on our webisite.
caas.symbioticeda.com/
We can also generate bitsteams for Tangnano9k. Please understand that we use the more modern Himbaechtel placer&router.
We can grab gateware designs from github
27 Jan 2024 11:45 #291743 by eduardo20
Under nextpnr there is a new placer&router for gowin devices called Himbaechtel which generates much better results.
27 Jan 2024 21:44 #291767 by meister
Thanks for the tip with Himbaechtel, I will give it a try,
but I don't think we need a CAAS web service for this project.
BTW: Arty7 with onboard Ethernet works now :)
www.youtube.com/shorts/0F0jCE0DY8k
28 Jan 2024 12:46 #291795 by eduardo20
That is great.
Do you generate the bitstream For Arty7 with the open source FPGA tools for Xilinx?
github.com/openXC7
That would be awesome!
28 Jan 2024 20:21 #291825 by meister
thanks,
not yet, using only the oss tools from the oss-cad-suite
Time to create page: 0.242 seconds
