- Hardware & Machines
- Computers and Hardware
- LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
- meister
- Thank you received: 502
27 Jun 2024 11:30 - 27 Jun 2024 11:42 #303887
by meister
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
you can also try to run RIO on you Spartan6 board, it's not sooo hard to port it.
EDIT: the supported Arty-a7-35t uses also the vivado toolchain,
in the best case only :
cp ./riocore/boards/Arty-a7-35t.json ./riocore/boards/Spartan6.json
and edit the default pins, type, clock and package values
then you can create a new config with "boardcfg": "Spartan6",
Last edit: 27 Jun 2024 11:42 by meister.
The following user(s) said Thank You: Cant do this anymore bye all
- Thank you received: 426
27 Jun 2024 12:19 #303893
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Now that's interesting, the daughter boards I made were designed to match a DB25 config, ie can be used with std PPort BoBs or Mesa DB25 daughter cards. ATM I've been using the XISE toolchain on Linux. That would also give me the option of Ethernet as well. And use the RPi5.
Here's a link to what I've been doing, has 5v to 3.3v level shifting on board. Really need bufferes to drive anything that requires current but then each pin can be used as an input or output. I took a lot of inspiration from the 7c81 schematics.
forum.linuxcnc.org/show-your-stuff/51142...tan-6-fpga-card-9d60
Thanks, (I think my energy is being renewed!) I'll give this a good look into cos ATM I've only got the option of SPI using my RP-400 or EPP using a PC, and I really was hoping to use the RPi5 via SPI but no driver.
So same hardware, RIO bit files & Ethernet vi the module I have floating around.
27 Jun 2024 12:59 #303896
Just had a quick look, seems vivado doesn't support Spartan6, so I guess I'll have to load everything into XISE and create ucf (pin file so suit), hopefully shouldn't be too much trouble. But that's tomorrow's task.
- meister
27 Jun 2024 13:09 #303897
by meister
you are right, i see, but no panic
github.com/multigcs/riocore/blob/main/ri...boards/Spartan6.json
github.com/multigcs/riocore/blob/main/ri...an6/config-test.json
#:/usr/src/riocore$ PYTHONPATH=. python3 bin/rio-generator riocore/configs/Spartan6/config-test.json
loading: riocore/configs/Spartan6/config-test.json
loading board setup: Spartan6
writing gateware to: Output/Spartan6/Gateware
!!! gateware changed: needs to flash |||
loading toolchain ise
writing linuxcnc files to: Output/Spartan6/LinuxCNC#:/usr/src/riocore/Output/Spartan6/Gateware$ clear ; make clean all
rm -rf rio.ngc rio.ngd rio.ncd parout.ncd rio.bit
cat debouncer.v toggle.v pwmmod.v rio.v > rio-modules.v
echo 'run -ifn rio-modules.v -ifmt Verilog -ofn rio.ngc -top rio -p xc6slx9-3tqg144 -opt_mode Speed -opt_level 1' | xst
Release 14.7 - xst P.20131013 (lin64)
Copyright (c) 1995-2013 Xilinx, Inc. All rights reserved.
TABLE OF CONTENTS
1) Synthesis Options Summary
2) HDL Parsing
3) HDL Elaboration
4) HDL Synthesis
4.1) HDL Synthesis Report
5) Advanced HDL Synthesis
5.1) Advanced HDL Synthesis Report
6) Low Level Synthesis
7) Partition Report
8) Design Summary
8.1) Primitive and Black Box Usage
8.2) Device utilization summary
8.3) Partition Resource Summary
8.4) Timing Report
8.4.1) Clock Information
8.4.2) Asynchronous Control Signals Information
8.4.3) Timing Summary
8.4.4) Timing Details
8.4.5) Cross Clock Domains Report
* Synthesis Options Summary *
---- Source Parameters
Input File Name : "rio-modules.v"
Input Format : Verilog
---- Target Parameters
Output File Name : "rio.ngc"
Target Device : xc6slx9-3tqg144
---- Source Options
Top Module Name : rio
---- General Options
Optimization Goal : Speed
Optimization Effort : 1
* HDL Parsing *
Analyzing Verilog file "rio-modules.v" into library work
Parsing module <debouncer>.
Parsing module <toggle>.
Parsing module <pwmmod>.
Parsing module <rio>.
* HDL Elaboration *
Elaborating module <rio>.
WARNING:HDLCompiler:872 - "rio-modules.v" Line 94: Using initial value of ESTOP since it is never assigned
WARNING:HDLCompiler:1127 - "rio-modules.v" Line 98: Assignment to ERROR ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "rio-modules.v" Line 121: Assignment to tx_data ignored, since the identifier is never used
WARNING:HDLCompiler:634 - "rio-modules.v" Line 103: Net <rx_data[7]> does not have a driver.
* HDL Synthesis *
Synthesizing Unit <rio>.
Related source file is "/usr/src/riocore/Output/Spartan6/Gateware/rio-modules.v".
BUFFER_SIZE = 16'b0000000000101000
WARNING:Xst:647 - Input <sysclk_in> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:653 - Signal <rx_data<7>> is used but never assigned. This sourceless signal will be automatically connected to value GND.
Summary:
no macro.
Unit <rio> synthesized.
Found no macro
* Advanced HDL Synthesis *
Found no macro
* Low Level Synthesis *
Optimizing unit <rio> ...
Mapping all equations...
Building and optimizing final netlist ...
Found area constraint ratio of 100 (+ 0) on block rio, actual ratio is 0.
Final Macro Processing ...
Final Register Report
Found no macro
* Partition Report *
Partition Implementation Status
No Partitions were found in this design.
* Design Summary *
Top Level Output File Name : rio.ngc
Primitive and Black Box Usage:
# BELS : 1
# GND : 1
# IO Buffers : 1
# OBUF : 1
Device utilization summary:
Selected Device : 6slx9tqg144-3
Slice Logic Utilization:
Slice Logic Distribution:
Number of LUT Flip Flop pairs used: 0
Number with an unused Flip Flop: 0 out of 0
Number with an unused LUT: 0 out of 0
Number of fully used LUT-FF pairs: 0 out of 0
Number of unique control sets: 0
IO Utilization:
Number of IOs: 2
Number of bonded IOBs: 1 out of 102 0%
Specific Feature Utilization:
Partition Resource Summary:
Timing Report
NOTE: THESE TIMING NUMBERS ARE ONLY A SYNTHESIS ESTIMATE.
FOR ACCURATE TIMING INFORMATION PLEASE REFER TO THE TRACE REPORT
GENERATED AFTER PLACE-and-ROUTE.
Clock Information:
No clock signals found in this design
Asynchronous Control Signals Information:
No asynchronous control signals found in this design
Timing Summary:
Speed Grade: -3
Minimum period: No path found
Minimum input arrival time before clock: No path found
Maximum output required time after clock: No path found
Maximum combinational path delay: No path found
Timing Details:
All values displayed in nanoseconds (ns)
Cross Clock Domains Report:
Total REAL time to Xst completion: 4.00 secs
Total CPU time to Xst completion: 3.96 secs
Total memory usage is 361140 kilobytes
Number of errors : 0 ( 0 filtered)
Number of warnings : 6 ( 0 filtered)
Number of infos : 0 ( 0 filtered)
ngdbuild -p xc6slx9-3tqg144 -uc pins.ucf rio.ngc
Release 14.7 - ngdbuild P.20131013 (lin64)
Command Line: /data/opt/Xilinx/14.7/ISE_DS/ISE/bin/lin64/unwrapped/ngdbuild -p
Reading NGO file "/usr/src/riocore/Output/Spartan6/Gateware/rio.ngc" ...
Gathering constraint information from source properties...
Done.
Annotating constraints to design from ucf file "pins.ucf" ...
Resolving constraint associations...
Checking Constraint Associations...
Done...
Checking expanded design ...
NGDBUILD Design Results Summary:
Number of errors: 0
Number of warnings: 0
Writing NGD file "rio.ngd" ...
Total REAL time to NGDBUILD completion: 2 sec
Total CPU time to NGDBUILD completion: 2 sec
Writing NGDBUILD log file "rio.bld"...
NGDBUILD done.
map -detail -pr b rio.ngd
Release 14.7 - Map P.20131013 (lin64)
Using target part "6slx9tqg144-3".
Mapping design into LUTs...
Writing file rio.ngm...
Running directed packing...
Running delay-based LUT packing...
Updating timing models...
INFO:Map:215 - The Interim Design Summary has been generated in the MAP Report
(.mrp).
Running timing-driven placement...
Total REAL time at the beginning of Placer: 3 secs
Total CPU time at the beginning of Placer: 3 secs
Phase 1.1 Initial Placement Analysis
Phase 1.1 Initial Placement Analysis (Checksum:1f2fb3a9) REAL time: 3 secs
Phase 2.7 Design Feasibility Check
Phase 2.7 Design Feasibility Check (Checksum:1f2fb3a9) REAL time: 3 secs
Phase 3.31 Local Placement Optimization
Phase 3.31 Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 3 secs
Phase 4.2 Initial Placement for Architecture Specific Features
(Checksum:1f2fb3a9) REAL time: 4 secs
Phase 5.36 Local Placement Optimization
Phase 5.36 Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 6.30 Global Clock Region Assignment
Phase 6.30 Global Clock Region Assignment (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 7.3 Local Placement Optimization
Phase 7.3 Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 8.5 Local Placement Optimization
Phase 8.5 Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 9.8 Global Placement
Phase 9.8 Global Placement (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 10.5 Local Placement Optimization
Phase 10.5 Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 11.18 Placement Optimization
Phase 11.18 Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 12.5 Local Placement Optimization
Phase 12.5 Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 13.34 Placement Validation
Phase 13.34 Placement Validation (Checksum:1f2fb3a9) REAL time: 4 secs
Total REAL time to Placer completion: 4 secs
Total CPU time to Placer completion: 3 secs
Running post-placement packing...
Writing output files...
Design Summary:
Number of errors: 0
Number of Slice Registers: 0 out of 11,440 0%
Number of Slice LUTs: 0 out of 5,720 0%
Number of occupied Slices: 0 out of 1,430 0%
Number of MUXCYs used: 0 out of 2,860 0%
IO Utilization:
Number of bonded IOBs: 2 out of 102 1%
Number of LOCed IOBs: 2 out of 2 100%
Number of RAMB16BWERs: 0 out of 32 0%
Number of RAMB8BWERs: 0 out of 64 0%
Number of BUFIO2/BUFIO2_2CLKs: 0 out of 32 0%
Number of BUFIO2FB/BUFIO2FB_2CLKs: 0 out of 32 0%
Number of BUFG/BUFGMUXs: 0 out of 16 0%
Number of DCM/DCM_CLKGENs: 0 out of 4 0%
Number of ILOGIC2/ISERDES2s: 0 out of 200 0%
Number of IODELAY2/IODRP2/IODRP2_MCBs: 0 out of 200 0%
Number of OLOGIC2/OSERDES2s: 0 out of 200 0%
Number of BSCANs: 0 out of 4 0%
Number of BUFHs: 0 out of 128 0%
Number of BUFPLLs: 0 out of 8 0%
Number of BUFPLL_MCBs: 0 out of 4 0%
Number of DSP48A1s: 0 out of 16 0%
Number of ICAPs: 0 out of 1 0%
Number of MCBs: 0 out of 2 0%
Number of PCILOGICSEs: 0 out of 2 0%
Number of PLL_ADVs: 0 out of 2 0%
Number of PMVs: 0 out of 1 0%
Number of STARTUPs: 0 out of 1 0%
Number of SUSPEND_SYNCs: 0 out of 1 0%
Average Fanout of Non-Clock Nets: 0.00
Peak Memory Usage: 650 MB
Total REAL time to MAP completion: 4 secs
Total CPU time to MAP completion: 4 secs
Mapping completed.
See MAP report file "rio.mrp" for details.
par -w rio.ncd parout.ncd rio.pcf
Release 14.7 - par P.20131013 (lin64)
Constraints file: rio.pcf.
Loading device for application Rf_Device from file '6slx9.nph' in environment /data/opt/Xilinx/14.7/ISE_DS/ISE/.
"rio" is an NCD, version 3.2, device xc6slx9, package tqg144, speed -3
Initializing temperature to 85.000 Celsius. (default - Range: 0.000 to 85.000 Celsius)
Initializing voltage to 1.140 Volts. (default - Range: 1.140 to 1.260 Volts)
INFO:Par:282 - No user timing constraints were detected or you have set the option to ignore timing constraints ("par
-x"). Place and Route will run in "Performance Evaluation Mode" to automatically improve the performance of all
internal clocks in this design. Because there are not defined timing requirements, a timing score will not be
reported in the PAR report in this mode. The PAR timing summary will list the performance achieved for each clock.
Note: For the fastest runtime, set the effort level to "std". For best performance, set the effort level to "high".
Device speed data version: "PRODUCTION 1.23 2013-10-13".
Device Utilization Summary:
IO Utilization:
Overall effort level (-ol): Standard
Router effort level (-rl): High
Starting initial Timing Analysis. REAL time: 2 secs
Finished initial Timing Analysis. REAL time: 2 secs
WARNING:Par:288 - The signal sysclk_in_IBUF has no load. PAR will not attempt to route this signal.
Starting Router
Phase 1 : 1 unrouted; REAL time: 2 secs
Phase 2 : 1 unrouted; REAL time: 2 secs
Phase 3 : 0 unrouted; REAL time: 3 secs
Phase 4 : 0 unrouted; (Par is working to improve performance) REAL time: 3 secs
Updating file: parout.ncd with current fully routed design.
Phase 5 : 0 unrouted; (Par is working to improve performance) REAL time: 3 secs
Phase 6 : 0 unrouted; (Par is working to improve performance) REAL time: 3 secs
Phase 7 : 0 unrouted; (Par is working to improve performance) REAL time: 3 secs
Phase 8 : 0 unrouted; (Par is working to improve performance) REAL time: 3 secs
Phase 9 : 0 unrouted; (Par is working to improve performance) REAL time: 3 secs
Phase 10 : 0 unrouted; (Par is working to improve performance) REAL time: 3 secs
Total REAL time to Router completion: 3 secs
Total CPU time to Router completion: 3 secs
Generating "PAR" statistics.
INFO:Par:459 - The Clock Report is not displayed in the non timing-driven mode.
Timing Score: 0 (Setup: 0, Hold: 0)
Generating Pad Report.
All signals are completely routed.
WARNING:Par:283 - There are 1 loadless signals in this design. This design will cause Bitgen to issue DRC warnings.
Total REAL time to PAR completion: 3 secs
Total CPU time to PAR completion: 3 secs
Peak Memory Usage: 602 MB
Placer: Placement generated during map.
Routing: Completed - No errors found.
Number of error messages: 0
Number of warning messages: 3
Number of info messages: 2
Writing design to file parout.ncd
PAR done!
#bitgen -w -g StartUpClk:CClk -g CRC:Enable parout.ncd rio.bit rio.pcf
bitgen -w -g StartUpClk:jtagclk -g CRC:Enable parout.ncd rio.bit rio.pcf
Release 14.7 - Bitgen P.20131013 (lin64)
Opened constraints file rio.pcf.
Thu Jun 27 15:03:00 2024
Running DRC.
DRC detected 0 errors and 0 warnings.
Creating bit map...
Saving bit stream in "rio.bit".
Bitstream generation is complete.
cp -v hash_new.txt hash_compiled.txt
'hash_new.txt' -> 'hash_compiled.txt'
- meister
27 Jun 2024 14:09 - 27 Jun 2024 14:10 #303900
by meister
if you can send me more info's of this board (cant find any).
then i can complete the board-config (clock pin and crystal-speed).
and if you have the pinout's of your interface-board, i can build a simple config
with some stepper outputs and digital-IO's + SPI interface
Last edit: 27 Jun 2024 14:10 by meister.
27 Jun 2024 14:36 #303903
I can do that in the morning, it’s just approaching half past midnight Down Under.
What I’ll do I’ll get everything together and put it on my github, schematics for my boards and everything I have on the FPGA, everything is a bit scattered ATM.
You realise if theory that the Mesa 7c81 and 7i90 could run the Spartan6 version of the rio firmware ? Both have SPI interfaces and the 7i90 when it was last in stock was about 50 USD plus delivery.
I’ve also got one the colorlight RV901T boards, spartan6 based I could test as well.
Seriously I’ve been struggling a bit with “chasing the black dog” recently but this has given me something to get my teeth into, once again many many thanks.
- meister
27 Jun 2024 17:24 #303912
by meister
RIO has no EPP and no Smart-Serial support, but I don't see what should speak against it
running RIO on Mesa hardware.
The only thing is, Mesa is very well supported and tested,
there is no reason to use RIO on Mesa.
27 Jun 2024 20:06 #303929
Tho I haven’t had a chance to play with one, the 7i90 looks like it would make a great general purpose FPGA learning board. 72 bi directional pins that are 5v tolerant due to the bus switches used, tho buffers would be needed to drive LEDs.
Plus the pins used by the EPP interface and 3.3 only pins on the SPI connector.
Electrically the smart serial interface is RS-422, nothing non standard there.
Actually I wasn’t actually suggesting doing it, was more academic than anything else. Just the rantings of a mad Aussie.
28 Jun 2024 01:03 #303947
Got the info together and placed it on github
github.com/ozzyrob/Linuxcnc-FPGA
- meister
28 Jun 2024 06:50 - 28 Jun 2024 08:23 #303955
by meister
have build a minimal bitfile (blinking LED's)
multixmedia.org/Spartan6.bit
if you like to test it
EDIT: update path (.bin -> .bit)
Last edit: 28 Jun 2024 08:23 by meister.
Time to create page: 0.197 seconds
