- Thank you received: 426
i have no problem with discarding initial concepts if it brings an advantage, unfortunately i still see disadvantages in softcore.I was just throwing it out there.
In all honesty it really doesn't go with the ethos of your project. From the beginning you wanted to stay away from softcores.
Just while I have it on my mind;
[/code]Code:reg [5:0] initialization_progress = 6'b000000; More code...... [code]end else if (state == STATE_INITIALIZING) begin spi_clk <= 1'b0; state <= STATE_SENDING_COMMAND; initialization_progress <= initialization_progress + 6'b000001; spi_chip_select_n <= 1'b0; spi_clock_count <= 10'd0; is_busy <= 1'b1; case (initialization_progress) // TODO: Perhaps add software reset here? 0: current_instruction <= SET_PHY_MODE; // Set our MAC address 1: current_instruction <= {SET_MAC_ADDRESS_BYTE_0, MAC_ADDR[47:40]}; 2: current_instruction <= {SET_MAC_ADDRESS_BYTE_1, MAC_ADDR[39:32]}; 3: current_instruction <= {SET_MAC_ADDRESS_BYTE_2, MAC_ADDR[31:24]}; 4: current_instruction <= {SET_MAC_ADDRESS_BYTE_3, MAC_ADDR[23:16]}; 5: current_instruction <= {SET_MAC_ADDRESS_BYTE_4, MAC_ADDR[15:8]}; 6: current_instruction <= {SET_MAC_ADDRESS_BYTE_5, MAC_ADDR[7:0]}; Am I right in thinking that SET_PHY_MODE is never acted on as initialization_progress is incremented before the case stanza ?
Understood, thanks for the advice/heads up. I have placed an order for the WT32-ETH01 and will receive this within 36~48hrs. I'll update.i prefer the WT32-ETH01, cheap and available
