2 years 2 months ago #307008 by meister
thank you PCW !
the Linear Scale works with quadencoder(z) plugin :)
but the part from my link is really cheap,
ok for playing around, but to use it properly, hmm, no
2 years 2 months ago #307010 by Mecanix
new toy :)
works like a rotary-encoder, i think it should work in RIO
Haha that's so cool. Their output are indeed identical to those 90deg ABZ rotary encoder. Plugs right in your quadencoderz plugin and so no extra work required!
In the other RIO gossips; a brand new journey is about to begin!! However and before I begin routing this I wanted to poke your expertise and ask what would define a half-perfect RIO Motion Control Board. Is there anything fancy that we need on that other than the usual SPINDLE + MPG + XYZAB + Ins & Outs?
2 years 2 months ago #307034 by meister
Sorry, was busy :)
@Mecanix
nice board !, but i answer you tomorrow, need sleep now
The following user(s) said Thank You: Mecanix
2 years 2 months ago - 2 years 2 months ago #307058 by meister
it always depends on the application,
as a universal board, I would say:
4 step/dir
4 inputs (selectable 24V/5V - Proximity Limit Switch)
1 encoder (for lathe / with differantal inputs)
>=3 inputs (for estop/misc)
>=3 outputs (cooling/spindle)
1 MODUS (vfd-spindle)
1 WS2812b (status display / only one pin needed)
1 PMOD header
I really like these connectors: www.reichelt.de/stiftleiste-2-pol-rm-3-5...rank&OFFSET=16&nbc=1
but it's a matter of taste :)
i think USB/Seriel is not necessary
the fpga on the tangnano20k has the same housing, if the pinout matches you could also use it !?!?!
not the same :(
EDIT: and it should work with cheap programmer like the USB-Blaster
Last edit: 2 years 2 months ago by meister.
2 years 2 months ago - 2 years 2 months ago #307059 by meister
i have noticed that you can also generate verilog with litex without soft-core. and that liteeth also supports UDP in hardware. I think it should be possible to build a UDP interface that runs on the Colorlite boards (and others) and can be integrated into RIO.
There are many supported FPGA's and PHY's: github.com/enjoy-digital/liteeth
2 years 2 months ago #307060 by kzali
Would the Tang Primer 20k be a good candidate
Time to create page: 0.992 seconds
