- Hardware & Machines
- Computers and Hardware
- LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
- Thank you received: 426
07 Aug 2024 17:14 #307189
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
For IO on my boards I used the method Mesa does, FET bus switches with pull up resistors on the “world side”. Granted a bob or other driver is required to interface to the “outside world”, but you have free reign over whether a individual pin is an input or output.
As the original intention was to use Mesa firmware I wanted to be able to interface with their DB25 daughter cards.
Also it quick way to convert an existing parallel port setup. Get the firmware config as needed with riogui, flash the FPGA and plug the existing parallel port bob in and off you go. No changes required to the existing wiring.
Anyway that’s just my take, I know it’s not 100% perfect.
07 Aug 2024 17:19 #307191
One thing to check with bi-directional chips is the drive, some are only recommended for short distance over pcb tracks, not generally recommended for driving signals over long wires.
The following user(s) said Thank You: meister, Mecanix
- Mecanix
- Thank you received: 229
07 Aug 2024 17:48 #307196
by Mecanix
Replied by Mecanix on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
That's all great insights and recommendations, thanks guys. And yes, bidirectional translation can skew a signal pretty quick (long traces/wires == parasitic capacitance). Sensitive. Perhaps not ideal for motion control board.
You guys experimented with modern digital isolators yet? Worth looking into or... stick to the medieval optos?
- meister
- Thank you received: 490
07 Aug 2024 18:02 #307197
by meister
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
The following user(s) said Thank You: Mecanix
- meister
07 Aug 2024 18:08 - 07 Aug 2024 18:10 #307198
by meister
Last edit: 07 Aug 2024 18:10 by meister.
- Mecanix
07 Aug 2024 18:11 #307199
by Mecanix
- meister
07 Aug 2024 18:23 #307201
by meister
i think with a universal small controller you should rather look at the price and use the tried and tested
- Mecanix
07 Aug 2024 18:32 - 07 Aug 2024 18:46 #307203
by Mecanix
I'm no control motion board expert by any trade. First one. The "Legend" has it that they are noisy and spikey. Mind you I'm having no issue running a colorlight on my lathe which share the same 5V&GND for pretty much everything (rotary encoder, switches, stepper drives, estop, everything basically). Just got isolation on the Spindle/BLDC motor drive (obviously), but that's on the drive itself not on the motion control board. And so I'm a bit lost as to what's best isolation design, low-cost, "convenience-wise".
btw - I apologize for hijacking your thread and abusing your kind generosity (and expertise!!). Just trying to get a semi-universal "RIO Control Board" schematic out for the community to copy/paste and ideally do their own...
Edit: perhaps worth using another forum for those sort of questions?! If so do not hesitate to recommend one/more/many, and I'll be on my way out!!
Last edit: 07 Aug 2024 18:46 by Mecanix.
- Mecanix
07 Aug 2024 18:50 - 07 Aug 2024 18:52 #307205
by Mecanix
Just checked my stepper drives and as expected (a.k.a. modern equipment), they do have built-in isolation (optos). Same as my spindle BLDC motor drive, all built-in modern stuff. And so wtf, why the excessive legendary need for so called isolation on those motion control boards for exactly?
Calling the electron godz lol...
Last edit: 07 Aug 2024 18:52 by Mecanix.
- meister
07 Aug 2024 18:58 #307207
by meister
yes, that's the reason why i only use opto's for the inputs and uln2003 for the outputs. That's perfectly adequate for the hobby sector
Time to create page: 0.186 seconds
