- Hardware & Machines
- Computers and Hardware
- LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
- Mecanix
- Thank you received: 229
07 Aug 2024 19:07 - 07 Aug 2024 19:20 #307208
by Mecanix
Replied by Mecanix on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Strange things those control boards, tell ya. Interfacing digital is no problem for me, but I'm having a really hard time understanding why most folks use optos yet share the same ground as the motion board. No use imho...
I'll look into this external/digital isolation when my head functions again (happens once or twice max per month that lol). Probably going to need that i s o l a t i o n 'as per the legend' , just dunno for what exactly.
Again, sorry for the hijack. I'm out. I'll update on progress ad schematics though. ~hacktheworld!
Last edit: 07 Aug 2024 19:20 by Mecanix.
- Mecanix
07 Aug 2024 19:16 #307209
by Mecanix
RIO related!!
Found a bug. They're really hard to find so I'm pretty happy about that
Should be "Angular", not rotary, in the axis joint/stepper plugin.
Enjoy your day, Olivier. All the best man.
- meister
- Thank you received: 502
07 Aug 2024 20:46 #307212
by meister
But if there's only one voltage source, it's also difficult.
Optos give you a better feeling
is fixed, many thanks !!!
all the best for you too
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
I feel guilty, I think I had separated GND for the tangoboard, but not for the others.Strange things those control boards, tell ya. Interfacing digital is no problem for me, but I'm having a really hard time understanding why most folks use optos yet share the same ground as the motion board. No use imho...
has everything to do with rio, all good !Again, sorry for the hijack. I'm out. I'll update on progress ad schematics though. ~hacktheworld!
- Mecanix
07 Aug 2024 20:46 #307213
by Mecanix
Crazy stuff. Linuxcnc's next level? AXIS Protocol... hardcoded lol
- meister
07 Aug 2024 20:59 #307217
by meister
This is also only UDP via an RMII device and without a soft core
we have everything, but not yet for all FPGAs and toolchains:
github.com/multigcs/riocore/tree/dev/riocore/plugins/rmii
github.com/multigcs/riocore/tree/dev/riocore/plugins/arty_mii
The following user(s) said Thank You: Mecanix
- Mecanix
07 Aug 2024 21:03 #307218
by Mecanix
How did I missed that out. omg
- meister
07 Aug 2024 21:04 #307219
by meister
I would like to bypass the UDP and IP layers, similar to Ethercat with its own lean protocol.
but then only a direct connection is possible, but a very fast one with minimal delay
- meister
07 Aug 2024 21:19 #307220
by meister
- Thank you received: 426
07 Aug 2024 22:18 #307226
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Optos driving optos, people copying other designs with no real knowledge. Or “it’s what someone on cnczone recommended”.
re UDP, it’s simple to setup, proven by years of implementation and works.
I think what would be great, is that the FPGA reports it’s capabilities to the driver so the driver doesn’t require rebuilding. Tho it would make things way more complicated to implement.
Regarding isolated drivers that topic did come up a little while ago maybe 12 ish months, so it is something that has discussed.
Oh yeah common grounds with optos, that’s something I just can’t fathom. Maybe there is a reason in some applications, but for the most common application, providing isolation, I don’t get it.
These could be an idea for output
www.icbase.com/File/PDF/ONS/ONS56621412.pdf
- Mecanix
07 Aug 2024 22:35 #307227
by Mecanix
What we currently have is STUPID FAST and high performance already. Unless a mysterious someone has a requirement for an hypersonic motion machine-tool, nobody here (in our star system anyway) will be able to ceiling the perf of RIO as-is on any parts/processes level.
Not sure what you did but after updating the git today I'm clocking this x2 speed of what it was a few days ago. Used to be 2.5ms, now down to little more than a millisecond. Impressive stuff, Olivier.
No Thank You Very Much. Interesting none the less.Also possible with W5500 on Mac level
Time to create page: 0.492 seconds
