- Thank you received: 502
Ok that's great, at least we know why it doesn't work on this pc. If I set the interface IP to 192.168.10.1 then I can't ping the fpga anymore. I'm confused. For the record the FPGA/w5500 is connected directly into the Wired connection 2.ahhh, ok, your lcnc host have the ip of the rio-interface, that explain also the udp-loop
set it to 192.168.10.1 or so
for subnet you can use 255.255.255.0 (bcast is than 192.168.10.255), but that should also work
