- Thank you received: 502
Ok, I'll delay the pcb fab a day and see what I can do with those lonely 15 GPIOs. I'll have them all via and TP on the back side of the PCB.if you still have io-pins free on the FPGA, put them on test-pads if you can, you can always use them
Well spotted, correct, those 9 parts are indeed the level shifting. Features digital isolation also, all in one part. I apologize for omitting the schematic for now, once I have it cleaned up and arranged I'll put it up. I'd like to test the board prior though. Regardless, here's a visual below of how it's arranged (ten inputs). Additionally, I'm getting us an ultra-low ripple Isolated 12V Supply done for that board. Plugs right on the main. If we are to isolate this FPGA/Motion Control thing, might as well isolate it true & properly!!Awesome, did you use any opto-couplers/digital isolators, are the nine 16-pin IC's only level-shifters?
