G92 messing up the coordinate
14 years 8 months ago #18095 by BigJohnT
Replied by BigJohnT on topic Re:G92 messing up the coordinate
I use G92 all the time on my plasma table so I know it does not mess up my coordinate system. Can you attach a bit of code that will reproduce the problem so we can help you?
14 years 8 months ago - 14 years 8 months ago #18097 by Rick G
Replied by Rick G on topic Re:G92 messing up the coordinate
As John said...
So do I on my router, mill and lathe without a problem.
You might want to look here..
linuxcnc.org/docs/html/common_User_Concepts.html#r1_5_3
Rick G
Last edit: 14 years 8 months ago by Rick G.
14 years 8 months ago - 14 years 8 months ago #18111 by KenC
Replied by KenC on topic Re:G92 messing up the coordinate
Hi John,
I write single command on the MDI screen. It will do its black magic everytime.
G92 Zxx.xx (xx.xx being any number, + or -ve)
That is all I need to do to screw everything up.
Hi Rick,
Thank for the pointer, will dig deep into the links you attached.
Thousand thanks.
Ken
Last edit: 14 years 8 months ago by KenC.
14 years 8 months ago #18126 by BigJohnT
Gee, can you be a bit more precise than "black magic" G92 Z anything works as expected for me and everyone else.
14 years 8 months ago - 14 years 8 months ago #18127 by KenC
John,
I have no idea what is the word to describe it...
I get “exceed join'ts limit" faithfully whenever I issue a second G92 command every time & if I ignore it & continue working, the machine will go to coordinates which are totally outside of all the soft limits.
This happens the same with V2.3.4 on 8,04 & the current 2.4.7
I have no intention to act like I'm cute or funny... but honestly, I have no other words to describe the mess made after I issue a G92 single command from the MDI command bar... everything is a mess & as these software "vocab" is voodoo to me...
Rick, I am not re-setting the machine co-ordinates, I still need the coordinated to remain so that the machine won't rush out of the soft limits. SO that G43, G49, G53 are not the things I want... I just want to re assign the work co-ordinate & not the machine cordinates.
Regards
Ken
14 years 8 months ago - 14 years 8 months ago #18128 by BigJohnT
Ok, Do you have a G54 offset in effect for the Z axis? In 2.4.x go to Machine > Zero Coordinate System and zero out the P1 G54 (which I assume your using).
Also, do you have a tool loaded with Tx M6 G43?
Last edit: 14 years 8 months ago by BigJohnT.
Time to create page: 0.124 seconds
