G92 messing up the coordinate
14 years 8 months ago #18135 by KenC
Replied by KenC on topic Re:G92 messing up the coordinate
Yes, the status bar says [ON] [No tool] [Position: Relative Actual]
14 years 8 months ago #18137 by BigJohnT
Replied by BigJohnT on topic Re:G92 messing up the coordinate
Ok, follow the steps in 5.3 to zero out any offsets you have.
linuxcnc.org/docview/2.5/html/common/Use...hen_you_8217_re_lost
14 years 8 months ago - 14 years 8 months ago #18138 by KenC
HiJohn,
Did exactly as 5.3
After all this, I issue a single G92 z-15 command & the DRO shows everything is Zero. BUT the Preview screen show the Z position at 381
Still the same problem....
Regards
Ken
Last edit: 14 years 8 months ago by KenC.
14 years 8 months ago #18139 by BigJohnT
You have to be viewing the machine position not the relative position. Change that on the View menu.
14 years 8 months ago #18140 by KenC
It is on relative position.
In Machine position, everything is Zero.
14 years 8 months ago #18143 by BigJohnT
Let's back up a bit and clarify some terminology as I'm having trouble understanding your terminology.
After you followed the steps in section 5.3 of the link did the DRO in the Preview Tab (upper left corner) and the DRO tab both show all axes to be 0.0000?
Did you home the Z axis after following the steps in section 5.3?
Can you explain exactly what your looking at when you say "the DRO shows everything is Zero. BUT the Preview screen show the Z position at 381"?
Time to create page: 0.129 seconds
