- Thank you received: 994
G92 messing up the coordinate
- BigJohnT
14 years 8 months ago - 14 years 8 months ago #17663
by BigJohnT
Replied by BigJohnT on topic Re:G92 messing up the coordinate
KenC wrote:
Are you saying that you jog the Z axis down to a point then with the Z axis radio button selected you click on the "Touch Off" button, then select "Tool Table" then click on the "Ok" button? If this is the case then you are adding the current G54 offset to your tool offset. In 2.4 always issue a G59.3 or similar (I used to use G55) to select a coordinate system that does not have any offsets before touching off the tool table or clear any G54 offsets before touching off the tool table.
Hi John,
The same problem persisted in any situation when ever I click on the Z-zeto touch-off the second time when I open up EMC2. & its not G-code file related.
Last edit: 14 years 8 months ago by BigJohnT.
- KenC
14 years 8 months ago #18071
by KenC
Replied by KenC on topic Re:G92 messing up the coordinate
I would like to report that my G92 is still messing up my machine co-ordinate...
G92.1 does reset the coordinates, but when I proceed with a new G92 issue, the coordinates mess us again...
Any help is highly appreciated.
Regards
Ken
Regards
Ken
- Rick G
- Thank you received: 114
14 years 8 months ago #18073
by Rick G
Replied by Rick G on topic Re:G92 messing up the coordinate
Are you using tool table offsets? Do you cancel them after use? Do the offsets in the tool table relate to your errors?
Can you try G10 L20 instead of G92 to set the coordinate system?
Rick G
Rick G
- BigJohnT
14 years 8 months ago #18080
by BigJohnT
Ken,
Your going to have to give us more information than "it's messing up" to get past your learning curve. Please tell us exactly what your doing, what you expected, and what you got along with a sample of the code that gives you the unexpected result.
- KenC
14 years 8 months ago - 14 years 8 months ago #18089
by KenC
To put things real simple. I use G92 to assign new coordinate value. Mostly on Z axis.
It will work nicely for the 1st time when I open EMC. & I can run a .ngc happily with it.
& when I wish to assign a new coordinate with G92, the warning bar at the bottom right of AXIS screen will flash "exceed joint's negative limit". without fail.
When I use G92.1, it will reset the DRO coordinate values but still flashes the "exceed joint's limit" warning.
So what I do to continue with work is G0 0,0 & close EMC. Re-open EMC & home all the axis all over again.
Again, I do my homing manually as I don't have limit switches installed.
I tried G10 L20, but I get warning asying "out of range"...
Regards
KEn
Regards
KEn
Last edit: 14 years 8 months ago by KenC.
- Rick G
14 years 8 months ago - 14 years 8 months ago #18092
by Rick G
Be sure to use P with G10
Such as G10 L20 P1 X0 Y0
Have you looked at your tool table?
Have you made sure all offsets are off such as G49?
linuxcnc.org/docs/html/gcode_main.html#sub:G43,-G49:-Tool
Rick G
Rick G
Last edit: 14 years 8 months ago by Rick G.
