Another tab for WebCam
- jmelson
- Thank you received: 160
Yes, I've had this too. It says "welcome Jon Elson" up next to the null avatar pic,BigJohnT wrote:
I always have to log back in. The web site remembers me, but I don't get logged in to the forum. So I need to click the _forum_ login button.Yea, it is strange it only happened to me once...
but "the web admin has disabled anonymous posting", so I have to log out and log
back in. This has happened a number of times when I don't visit the forum every
day.
Jon
- marzetti
- ArcEye
- Thank you received: 758
Same thing regularly for me, I get the greeting so it registers the cookie but I am not logged in.
Found that I don't need to log in, just press F5 (refresh) and I am logged back in.
Using Firefox 11
- strykerg
Hm, my fault. emc2 package name changed to linuxcnc so dependencies are a bit broken
psha did u manage ?
I've been playing a bit around with glade and with the use of the camera i managed to make a function i really wanted: rotate the program to reflect the rotated workpiece (i need it for double sided pcb's).
at first i tried to rotate and offset x and y at the same time but i am getting a small offset which i couldnt get rid off (maybe cuz g10 l2 rotates at machine origin?)
so by modifying the files i downloaded from wiki.linuxcnc.org/cgi-bin/wiki.pl?Axis_Embed_Video i made two functions. one to find rotation from four points (two on backplot and two on actual workpiece) and execute. g10 l2 p0 r
the other one simply does g10 l20 which offsets the saved pos to current pos.
tonight or tomorrow i will try and post everything here. in the meantime i have a couple of questions to the gurus here:
through glade, is it possible that a checkbox turns on and off the camera? (same as in control) i want to turn it off because when the camera is on, my cpu gets hogged at 100%.
is there a function i can do to reload the current program (ctrl-r) (this needs to be done after offsetting)
- psha
hope i'll have time today
if you want checkbox/togglebutton to turn camera on/off - probably I should add input pin for this. at least it's not possible to disable camera from gladevcp panel in axis
if you want to reload program - take a look on gladevcp actions, there is reload one
- strykerg
- strykerg
psha did u manage ?
here are the files. As i said its just a modified version of the ones found in wiki.linuxcnc.org/cgi-bin/wiki.pl?Axis_Embed_Video
what I did and how it works:
changed the way camon and cam off works so that it just does a relative move, with an offset which has been saved previously (meant to be used with a fixed camera)
MARK-CO: after performing a mark with the actual tool on the workpeice, this button is pressed to save current coordinates
CALIB-CO: with the camera centred on the above mark, pressing this will save the offsett between the tool and the camera
CAM checkbox: toggling this moves the axis so that the camera is in the place of the tool, or vice versa (performs a positive/negative g90 g0 with the saved offset)
SAVE XYZ wroks the same as before just added a debug so it shows the saved coord.
how to perform rotational offset:
load nc file and install workpeice. make sure there are no rotational offsets are present in the current coordinate system (G10 L2 P0 R0)
move to first reference point (lower leftish) on the backplot and press SAVE XYZ
move to the same point on the actual workpeice with camera and SAVE XYZ
move to the second reference point (upper rightish) on the backplot and SAVE XYZ
press ROTATE and then reload the program (CTRL+R) << cant find a way to do this automatically in the subroutine
performing X-Y offset
move to a reference point on the backplot and SAVE XYZ (point A)
move to the same reference point with the camera on the actual workpeice.
uncheck the CAM checkbox so that the tool will move in-place of the camera
press OFFSET and reload the program
i've known glade and oword routines for like 2days now so comments on any mistakes or suggesstions would be greatly appreciated.
- austin.mn
- Thank you received: 4994
Adding a webcam to my plasma machine is something I definitely want to do, but it seems the instructions for getting it set up apply to EMC2 and not Linuxcnc. If I try and get things working for me, I seem to be constantly running into trouble. Is there any instructions I can use to get my table set up with a webcam and keep my current configuration of linuxcnc?
I think the existing instructions ought to work, but with occasional substitution of "linuxcnc" for "emc2"
- ArcEye
I think the root of the problem is the .deb dependencies of the packages, requiring now deprecated files since the switch to linuxcnc.
Looks like the files in pshas /pool dir of his repository were last updated in Nov 2010
If you are comfortable with it, you can either use dpkg --force-depends options or simply download the packages and manually install the elements from them.
A .deb file in common with many others (.ipk etc) is simply a glorified .tar.gz. With a decent file manager like mc you can open it and transfer what you want from it to your system.
If that goes a bit beyond your comfort zone, you might have to wait for psha to update the packages.
He is a very busy chap in the development of Linuxcnc.
