Another tab for WebCam
- strykerg
15 Apr 2012 08:47 #19213
by strykerg
Replied by strykerg on topic Re:Another tab for WebCam
indeed ArcEye, thanks for your help. thumbs up
is there anywhere i can find examples or a guide for integrating functions in camview-emc like the one which centres the arc from 3 points?
- psha
15 Apr 2012 09:18 #19214
by psha
Replied by psha on topic Re:Another tab for WebCam
As i know only documentation available is this thread.
However if you read gladevcp docs and catch me on IRC i may guide you trough that process which may result in documentation
- strykerg
15 Apr 2012 10:24 #19217
by strykerg
great
will do.
first i need to make a proper spindle mount for the camera...
- strykerg
25 Apr 2012 14:09 - 25 Apr 2012 14:21 #19524
by strykerg
how did you guys manage to get the DRO showing on the camera image?
i know it has something to do with the emc.halio component however I dont seem to have it when I run camview
how can I get it ?
-edit-
i *think* I am on the process of figuring out how to make it with Glade. but gtg work now so it'll have to wait
how can I get it ?
-edit-
Last edit: 25 Apr 2012 14:21 by strykerg.
- ArcEye
- Thank you received: 758
25 Apr 2012 15:20 - 25 Apr 2012 15:22 #19527
by ArcEye
Replied by ArcEye on topic Re:Another tab for WebCam
Hi
You have to add it into the chain in camviewcfg
Don't think you ever said what version you are running.
Will not work with 8.04
www.linuxcnc.org/index.php/english/compo...98&catid=21&start=96
Last edit: 25 Apr 2012 15:22 by ArcEye.
- strykerg
26 Apr 2012 10:11 #19544
by strykerg
no i am running on lucid and linuxcnc 2.5. how do i add emc.halio to the camview chain? i don't have it.
btw couldn't find a Hal parameter/pin that holds the current axis position so i didn't manage with glade
- ArcEye
26 Apr 2012 10:55 - 26 Apr 2012 10:57 #19545
by ArcEye
Hi
I don't have camview-emc installed on my test machine any more and the workshop machines are 8.04
It looks like halio.so should be in /usr/lib/camunits
If it isn't, then get camunits-plugins-emc_0.0.6~lucid-i386.deb which contains it.
It should all be part of a standard install using psha's repository, I didn't have to download anything extra when I initially installed it to test the camera.
To quote his instructions page psha.org.ru/b/camview-emc.html
If you need extra functionality like DRO install camunits-plugins-emc.
Last edit: 26 Apr 2012 10:57 by ArcEye.
- strykerg
26 Apr 2012 10:58 #19546
by strykerg
ok found it... my bad didnt read the instruction manual
"If you need extra functionality like DRO install camunits-plugins-emc. It’s not available for Ubuntu 8.04 though. Also you may grab sources and build them yourself. But that’s not recommended since there are lot of dependencies and possible issues with plugin locations."
trying that now... thanks for you help ArcEye
- strykerg
26 Apr 2012 11:04 #19547
by strykerg
crap looks i fked up my linuxcnc installation
when i tried doing sudo apt-get install camunits-plugins-emc it said something like dependency missing "emc-sim" or emc-fake something like that
i installed that, then installed camunits plugins and now linuxcnc is gone
- psha
26 Apr 2012 11:27 #19549
by psha
Heh, i bet you've installed emc-sim?
emc-fake-sim is just a workaround ot provide one package for bot sim and rt installations
Just install emc2 back and you'll be fine
Time to create page: 0.547 seconds
