Another tab for WebCam
28 Mar 2011 00:19 - 28 Mar 2011 00:20 #8182 by Andy123
Replied by Andy123 on topic Re:Another tab for WebCam
Here is another problem:
I am trying to follow WIKI instructions and can't see any video if togle-caa.ui is included
EMBED_TAB_COMMAND = camview-emc -C camviewcfg -g togle-caa.ui -H campins.hal -w {XID}
I guess I am missing something again.
so far:
- Modified INI file to add [HALUI] section
- copied togle-caa.ui and campins.hal to config folder (from zip)
- copied nc programs to the folder defined in PROGRAM_PREFIX
Am I missing something?
Also WIKI shows DRAW halread that I don't have in camview...
Last edit: 28 Mar 2011 00:20 by Andy123.
28 Mar 2011 07:07 #8184 by psha
Replied by psha on topic Re:Another tab for WebCam
DRAW halread is old name of plugin. Now it's 'Read/write data to HAL pins' (emc.halio, in EMC section).
It's living in 'camunits-plugins-emc' package and not installed by default.
Also if you need panel in camview then you have to use EMC 2.5. GladeVcp was added only recently and not in 2.4
27 Apr 2011 02:02 - 27 Apr 2011 02:05 #9356 by Valen
Replied by Valen on topic Re:Another tab for WebCam
just wanted to say thanks for this,
all worked pretty much out of the box with a microsoft lifecam, even had the knobs for focus and zoom to twiddle.
Only issue I'm having is it defaults to a RGB input from the camera and that is using 100% of the CPU (its only an atom) even though the config file seems to be indicating a different format, (YUV, drops consumption to around 20-30%).
All the other parts of the chain are saved and working fine it just seems to not load the input resolution and format from the file.
Any suggestions?
Last edit: 27 Apr 2011 02:05 by Valen.
27 Apr 2011 06:35 #9361 by psha
I've added -f (--video-format) option to choose format you want. Note that it's simple substring matching.
I hope new packages (0.0.36) will land shortly in my repo. Or you may grab sources from git
27 Apr 2011 09:52 #9367 by andypugh
Replied by andypugh on topic Re:Another tab for WebCam
Running the webcam tab gives me "Unexpected Realtime Delay" on my otherwise well-behaved system. Perhaps I will try fiddling with the options.
11 May 2011 04:46 #9716 by Valen
Thanks for the change, works well, reduces cpu use from 100% to 40% or so on the dual core atom.
one further feature request, perhaps have it turn the camera off when the tab is hidden?
(i was thinking lost focus would be enough but that may get confusing)
I'm trying to get the HAL integration running now but I'm having some difficulties
pastebin.ca/2056568 is the result of running emc in a terminal window
I think these chunks are pertanent
Setting up pins for [(null)]
getting parameter 'halui.axis.0.pos-feedback'
Getting mutex 0xb75ba000
Got mutex
Got pin halui.axis.0.pos-feedback: (nil)
Release mutex
Released
parameter 'halui.axis.0.pos-feedback' not found
Axis 0: (nil)
I think perhaps its looking for axis.0.motor-pos-fb ?
also
campins.hal:10: Pin 'camview.hal_checkbutton1' does not exist
I believe this comes up when i click the camview tab
Any suggestions?
This is all running EMC2 - 2.6.0-pre0-297-gdc93387
26 Sep 2011 20:50 #13463 by howardsmith
Replied by howardsmith on topic Re:Another tab for WebCam
Can anyone tell my why I don't see the DRO in the camera window? Everything else works perfect except this.
Do I need to simply switch something on?
Thanks.
-Howard.
27 Sep 2011 04:53 #13468 by psha
Probably you have not installed package with halio plugin (camunits-plugins-emc)?
27 Sep 2011 16:49 #13473 by howardsmith
Perfect. Thank You.
-Howard
27 Sep 2011 23:08 #13478 by howardsmith
...not perfect. The DRO values are not correct. When jogging the machine, they jump wildly. Like, the numbers will go from values like 98723463554263475829+834757439285 to -98723463554263475829+834757439285 in an instant. Any thoughts?
-Howard.
Time to create page: 0.096 seconds
