Another tab for WebCam
- psha
27 Mar 2011 11:29 #8149
by psha
Replied by psha on topic Re:Another tab for WebCam
You are running RTAI kernel?
What video card/xorg driver?
Have you tried installing libgl1-mesa-swx11?
- Andy123
27 Mar 2011 11:41 #8150
by Andy123
Replied by Andy123 on topic Re:Another tab for WebCam
This is a standard RTAI install from live CD
it is running on Dell D610 with ATI Mobility Radeon X300 video card
I am not sure how to check XORG driver
Since this is a working CNC setup that I don't really want to touch or reinstall anything else untilI get another harddrive and make a clean install.
I have backup PC with Intel Atom MB that I may try later today, but if this does not work on D610, then I will not be able to use it on the actual machine
- psha
27 Mar 2011 11:49 #8151
by psha
Installing libgl1-mesa-swx11 is usually harmless and in some cases improves latency.
Also you may check it with livecd image without installing to hard drive - boot, run apt-get update and everything else just like in normal setup.
- Andy123
27 Mar 2011 11:55 #8152
by Andy123
I don't have latency problems with this setup - with disabled SMI I am running consistently below 7000, in most tests below 5000
If this is harmless then I will try it later on
- Andy123
27 Mar 2011 13:08 #8157
by Andy123
libgl1-mesa-swx11 took care of the OpenGL issue, I can see image now in camview and camview-emc
Now another problem - I added lines to [Display] section of INI file, but I don't see camera tab
Should it work in 2.4.6 or I need 2.5.?
- Andy123
27 Mar 2011 13:52 #8160
by Andy123
I am not sure what this means and what should I do with it?
What is .axisrc?
Download this file and place code from it in your .axisrc
What is .axisrc?
- psha
27 Mar 2011 14:38 #8161
by psha
You need either 2.5 or .axisrc.
.axisrc is file (starting with dot) in home directory
You should copy provided snippet there
- Andy123
27 Mar 2011 14:41 - 27 Mar 2011 14:49 #8162
by Andy123
I got it - thanks - I should read directions better
Last edit: 27 Mar 2011 14:49 by Andy123.
- psha
27 Mar 2011 14:49 #8163
by psha
No, if your username is 'andy123' you need to edit file '/home/andy123/.axisrc'
- Andy123
27 Mar 2011 14:50 #8164
by Andy123
I got it - I should read directions better
thanks
thanks
Time to create page: 0.148 seconds
