Axis Position Logger
5 years 8 months ago #198096 by BigJohnT
Replied by BigJohnT on topic Axis Position Logger
Can you test the changes? I don't have PyQt4 on my development PC...
JT
5 years 8 months ago #198125 by Tady
Replied by Tady on topic Axis Position Logger
The Send to Axis button is grayed out
5 years 8 months ago #198126 by Tady
Just for the sake of it I commented out
if IN_AXIS:
As expected the button on not grayed but I have an error
AttributeError: 'MyWindow' object has no attribute 'g_code'
Am I running the program wrong? The Log button logs the commands without problems
5 years 8 months ago - 5 years 8 months ago #198134 by Tady
I managed to get it working
I changed this
def sendToAxis(self): gcode = [str(self.gcodeList.item(i).text()) for i in range(self.gcodeList.count())] #sys.stdout.write(self.g_code.get(0.0, END)) sys.stdout.write('\n'.join(gcode)+"\nM2") # Add M2 to the end so LinuxCNC is happy
The Position logger needs to be opened with LinuxCNC for the button to work. If you run it in a separate terminal it doesn't work. Maybe because it is a separate process..
And you need to use Gmoccapy if you want to move the machine to log different positions. AXIS does not work, it looks like it is frozen while position logger is open
Last edit: 5 years 8 months ago by Tady.
5 years 8 months ago - 5 years 8 months ago #198164 by BigJohnT
Axis in LinuxCNC 2.8 works fine with the position logger running. However sys.stdout.write does not work with Axis.
JT
Last edit: 5 years 8 months ago by BigJohnT.
5 years 8 months ago #198187 by Tady
I'm using 2.9.. And with the above changes and Gmocappy works great.. It would be better if I didn't need to close the program to publish the gcode but hey that is wishfull thinking :)
Thank you for the program. In my opinion it should be integrated in LinuxCNC
The following user(s) said Thank You: BigJohnT
Time to create page: 0.854 seconds
