- Thank you received: 229
Axis Position Logger
- Mecanix
2 years 8 months ago #294213
by Mecanix
Replied by Mecanix on topic Axis Position Logger
$ sudo dpkg -i /home/ehsan/emclog_1.0.0_all.deb
$ sudo apt -f install
The following user(s) said Thank You: Ehsan_R
- Ehsan_R
2 years 8 months ago - 2 years 8 months ago #294240
by Ehsan_R
Replied by Ehsan_R on topic Axis Position Logger
ehsan@debian:~$ sudo dpkg -i /home/ehsan/emclog_1.0.0_all.deb
Selecting previously unselected package emclog.
(Reading database ... 165701 files and directories currently installed.)
Preparing to unpack .../ehsan/emclog_1.0.0_all.deb ...
Unpacking emclog (1.0.0) ...
dpkg: dependency problems prevent configuration of emclog:
emclog depends on python; however:
Package python is not installed.
emclog depends on python-pyqt5; however:
Package python-pyqt5 is not installed.
dpkg: error processing package emclog (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for man-db (2.11.2-2) ...
Errors were encountered while processing:
emclog
ehsan@debian:~$ sudo apt -f install
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Correcting dependencies... Done
The following packages will be REMOVED:
emclog
0 upgraded, 0 newly installed, 1 to remove and 3 not upgraded.
1 not fully installed or removed.
After this operation, 48.1 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 165709 files and directories currently installed.)
Removing emclog (1.0.0) ...
Last edit: 2 years 8 months ago by Ehsan_R.
- Thank you received: 7491
2 years 8 months ago #294241
Replied by tommylight on topic Axis Position Logger
sudo apt install python-pyqt5
Also try
But this might not work as python is now python3.
Package you are trying to install has emc in the name, makes me think it is way to old as that was the name of the LinuxCNC project a few years back, it was EMC2.
Also try
- Ehsan_R
2 years 8 months ago #294244
by Ehsan_R
ehsan@debian:~$ sudo apt install python-pyqt5
E: Unable to locate package python-pyqt5
ehsan@debian:~$ sudo apt install python3-pyqt5
python3-pyqt5 is already the newest version (5.15.9+dfsg-1).
The following packages were automatically installed and are no longer required:
linux-headers-6.1.0-13-amd64 linux-headers-6.1.0-13-common
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-6.1.0-18-rt-amd64 (6.1.76-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-18-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-18-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-18-rt-amd64
/etc/kernel/postinst.d/z50-raspi-firmware:
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/kernel/postinst.d/z50-raspi-firmware exited with return code 1
dpkg: error processing package linux-image-6.1.0-18-rt-amd64 (--configure):
installed linux-image-6.1.0-18-rt-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-rt-amd64:
linux-image-rt-amd64 depends on linux-image-6.1.0-18-rt-amd64 (= 6.1.76-1); however:
Package linux-image-6.1.0-18-rt-amd64 is not configured yet.
dpkg: error processing package linux-image-rt-amd64 (--configure):
E: Sub-process /usr/bin/dpkg returned an error code (1)
- Ehsan_R
2 years 8 months ago #294247
by Ehsan_R
Hello, I have just joined the LinuxCNC forum and I don't know much about LinuxCNC
If possible, explain exactly what I should do?
How can I edit and customize the files of this project?
2 years 8 months ago #294251
sudo dpkg -P raspi-firmware
sudo apt dist-upgrade
Then try again
And try this version, should be more up to date
jethornton.github.io/emclog/index.html
Code:update-initramfs: Generating /boot/initrd.img-6.1.0-18-rt-amd64 /etc/kernel/postinst.d/z50-raspi-firmware: raspi-firmware: missing /boot/firmware, did you forget to mount it? run-parts: /etc/kernel/postinst.d/z50-raspi-firmware exited with return code 1
Then try again
Time to create page: 0.151 seconds
