- Thank you received: 229
Axis Position Logger
- Mecanix
2 years 8 months ago #294471
by Mecanix
Replied by Mecanix on topic Axis Position Logger
Aren't those GTK ui Axis Tabs friendly? I could be wrong, and much like Tommy recommended (pyvcp), I think you can also have it all running from inside linuxcnc e.g AXISTAB: [Preview] | [DRO] | [EMCLOG]
Search for GladeVCP if interested in learning new tricks. Something like below, not far off anyway...
INI file
INI file
[DISPLAY]
EMBED_TAB_NAME = EMCLOG
MBED_TAB_LOCATION = ntb_user_tabs1
EMBED_TAB_COMMAND = halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u ./emclog/emclog.py ./emclog/emclog.ui
- phillc54
- Thank you received: 2100
2 years 8 months ago #294476
by phillc54
Replied by phillc54 on topic Axis Position Logger
- Thank you received: 2177
2 years 8 months ago #294497
Replied by Aciera on topic Axis Position Logger
The logger ui uses pyqt not gtk (ie it's not a glade panel).
The following user(s) said Thank You: Ehsan_R
2 years 8 months ago #294514
You can execute a python script using a custom M-code:
1. I have the folders 'libemclog' and 'mcodes' in my config folder
2. the [RS274NGC] section of the ini file must contain the path to the 'mcodes' folder:
3. Executing 'm129' opens the loggerui window.
I have modified emclog.py so the file handling (Open, Save, SaveAs) is a bit more user friendly.
Note: I'm on a rip installation so I'm not sure the paths are correct for a deb install.
USER_M_PATH = ./mcodes
2 years 8 months ago #294516
Forgot:
The point was that you can create a button in the gui and connect it to an MDI command in hal.
[HALUI]
MDI_COMMAND = M129
[HALUI]
MDI_COMMAND = M129
2 years 8 months ago - 2 years 8 months ago #294591
Here is my last version.
I removed everything I could not get working and added a bit more functionality to the context menu (right click in the gCode list)
[edit]
Update:
- Shows now the current file path above the GCode window
- Creates the Axes CheckBoxes and PositionLabels dynamically from the active axes information
- Fixed the Arc move functionality
Note: Still untested on a deb install.
[edit]
Update:
Last edit: 2 years 8 months ago by Aciera.
Time to create page: 0.325 seconds
