Axis Position Logger
4 years 6 months ago #241277
Replied by andypugh on topic Axis Position Logger
You might need to also install linuxcnc-uspace-dev
- jurod
- Thank you received: 6
4 years 6 months ago #241455
by jurod
Replied by jurod on topic Axis Position Logger
I have it installed.
OK works for version 2.8.2, but switches to 2.9.0 it can't find the "linuxcnc" module.
This works correctly when switched to 2.8.2 again without any reinstallation of Position Logger.
In version 2.9.0 it still looks for some !linuxcnc! module.
Is it called something else in the 2.9.0?
From emclog.py:
From emclog.py:
#! /usr/bin/python
import os, sys, math
if sys.version_info[0] > 2:
raise Exception("Python 2 is required.")
import ConfigParser
import linuxcnc
from PyQt5 import uic
from PyQt5.QtWidgets import (QApplication, QMainWindow, QCheckBox, QRadioButton,
QMessageBox, QFileDialog, QMenu)
from PyQt5.QtCore import Qt, QTimer, QEvent
IN_AXIS = os.environ.has_key("AXIS_PROGRESS_BAR")
if os.path.split(sys.argv[0])[0] == '/usr/bin':
GUI_PATH = '/usr/lib/python3/dist-packages/libemclog'
print('Installed')
if os.path.split(sys.argv[0])[0] == '.':
GUI_PATH = os.path.split(os.path.realpath(sys.argv[0]))[0]
print('In Development')
- jurod
4 years 6 months ago #241458
by jurod
or it has something to do with python2.7 and python3
- cakeslob
- Thank you received: 280
4 years 6 months ago #241723
by cakeslob
Replied by cakeslob on topic Axis Position Logger
Hey jurod, offtopic, but I have seen you and user domi appear to have a czech(?) modified version of axis, I was wondering where you found it
- jurod
4 years 5 months ago - 4 years 5 months ago #241802
by jurod
I didn't find it, but I did it. Slovak language.
forum.strojirenstvi.cz/viewtopic.php?t=31115
Last edit: 4 years 5 months ago by jurod.
The following user(s) said Thank You: tommylight, cakeslob
- jurod
4 years 5 months ago #242365
by jurod
I've been working on it for a week. Does anyone know why it can't find the linuxcnc module?
Time to create page: 0.313 seconds
