Axis 2 - touchscreen version of old friend
4 years 1 week ago - 3 years 8 months ago #254848 by zack
you must use the new attached file in the reply above for requested changes and put it in user/share/axis/tcl with privileges
Last edit: 3 years 8 months ago by zack.
The following user(s) said Thank You: tommylight, Masiwood123
4 years 1 week ago #254849 by Masiwood123
Replied by Masiwood123 on topic Axis 2 - touchscreen version of old friend
Ok.I'm not in the workshop right now, but I'll be there during the day and report back..
4 years 1 week ago #254852 by Masiwood123
that is it ,everything works except vfd spindle speed reading rpm, it stays at zero. I tried to insert a custom pyvcp spindle panel, but then it gives me an error that the ``spindle-speed'' line is duplicated. I would like to ask for one more if it is not difficult, is it possible to add another custom MDI because I need another control (m65 p0) independent that will turn off the relay for changing the mode between A and S (for me, the axis and spindle work with the same driver and I often change his mode) thank you
The following user(s) said Thank You: zack
4 years 1 week ago - 3 years 11 months ago #254894 by zack
Please send another screenshot, try change the color please.Your file attached.
Last edit: 3 years 11 months ago by zack.
4 years 1 week ago #254897 by Masiwood123
great, vfd again doesnt show rpm, but in gladavcp it show.
4 years 1 week ago #254899 by zack
ok post your hal files etc
the spindle could be configured to a different pin or it may be spindle 2/3 or so on
i need to see your ini and hal files along with glade panel if possible.
Time to create page: 2.594 seconds
