Axis 2 - touchscreen version of old friend
4 years 1 week ago #254903 by Masiwood123
Replied by Masiwood123 on topic Axis 2 - touchscreen version of old friend
File Name: gvcp_options.hal
File Size:1 KB
File Name: pyvcp-panel.xml
File Size:1 KB
File Name: gvcp_call_list.hal
File Size:0 KB
File Name: ss_2022-10-24.ini
File Size:5 KB
File Name: ss_2022-10-24.hal
File Size:14 KB
File Name: gvcp-panel.ui
File Size:6 KB
thanks Zack, here I have attached the files
4 years 1 week ago - 4 years 1 week ago #254909 by zack
Try this please - attached below
Last edit: 4 years 1 week ago by zack.
The following user(s) said Thank You: Masiwood123
4 years 1 week ago #254911 by Masiwood123
same:)
4 years 1 week ago - 2 years 9 months ago #254912 by zack
Sorry wrong file - in my haste, sent you the original - please try again
Last edit: 2 years 9 months ago by zack.
4 years 1 week ago - 4 years 1 week ago #254916 by Masiwood123
   thanks for your effort. now the error is that the line in the hall is not recognizable
Last edit: 4 years 1 week ago by Masiwood123.
3 years 1 month ago #281351 by Donno
Replied by Donno on topic Axis 2 - touchscreen version of old friend
I tested this on Linuxcnc 2.10pre and works great !
Maybe add a readme.txt in zip with instructions to install ??
Setup Instructions Main set display = axis2 in your ini sudo cp -a /home/donno/Downloads/axis2/icons/. /usr/share/axis/images sudo cp /home/donno/Downloads/axis2/axis2.tcl /usr/share/axis/tcl sudo chmod +x /home/donno/Downloads/axis2/axis2.tcl sudo cp /home/donno/Downloads/axis2/axis2 /usr/bin sudo chmod +x /usr/bin/axis2 sudo cp /home/donno/Downloads/axis2/glcanon.py /usr/lib/python3/dist-packages/rs274/ sudo chmod +x /usr/lib/python3/dist-packages/rs274/glcanon.py Linuxcnc-DEV set display = axis2 in your ini sudo cp -a /home/donno/Downloads/axis2/icons/. /home/donno/linuxcnc-dev/share/axis/images/ sudo cp /home/donno/Downloads/axis2/axis2.tcl /home/donno/linuxcnc-dev/share/axis/tcl/axis2.tcl sudo chmod +x /home/donno/linuxcnc-dev/share/axis/tcl/axis2.tcl sudo cp /home/donno/Downloads/axis2/axis2 /usr/bin sudo chmod +x /usr/bin/axis2 sudo cp /home/donno/Downloads/axis2/glcanon.py /usr/lib/python3/dist-packages/rs274/ sudo chmod +x /usr/lib/python3/dist-packages/rs274/glcanon.py
where "donno" should be your username
The following user(s) said Thank You: tommylight, zack, Aciera, Soccer Kid
Time to create page: 1.166 seconds
