- Thank you received: 25
Axis 2 - touchscreen version of old friend
- pgf
1 year 6 months ago #325956
by pgf
Replied by pgf on topic Axis 2 - touchscreen version of old friend
Well that's frustrating -- found this thread, got excited, read it to the end, and... crickets.
What happened?
What happened?
1 year 6 months ago #325989
Replied by andypugh on topic Axis 2 - touchscreen version of old friend
I am a but puzzled too, there was talk of adding it to LinuxCNC, and a suggestion that it might already have been done. But I don't see any "axis2" in the code.
I am fairly sure that it _isn't_ the UI in sim/gaxis, but perhaps that could work for you?
- pgf
1 year 6 months ago #326010
by pgf
I don't find sim/gaxis, but I did find sim/gscreen, which is interesting. But I've also in the meantime found JT's Flexible UI thread, and I like the idea of being able to customize it easily. Having written a somewhat complex pyvcp panel for axis, that I now realize I can't use anywhere else, I'd rather the customization options are baked in from the start.
The following user(s) said Thank You: zack
- Soccer Kid
- Thank you received: 7
1 year 6 months ago #326336
by Soccer Kid
Replied by Soccer Kid on topic Axis 2 - touchscreen version of old friend
Your work is excellent and simplifies the understanding of not understanding Linux. Thank you very much!
- michaeln
- Thank you received: 14
1 year 4 months ago - 1 year 4 months ago #331032
by michaeln
Replied by michaeln on topic Axis 2 - touchscreen version of old friend
Hello,
i think there is an error and think it must be:
sudo chmod +x /usr/share/axis/tcl/axis2.tcl instead of sudo chmod +x /home/donno/Downloads/axis2/axis2.tcl
(third line with sudo)
[/code][/b][/b][/code][/b][/b][/b][/code][/b][/b][/b][/code][/b][/b][/b][/code]Code:[b][b][b][code][b][b][b][code][b][b][b][code][b][b][code]I tested this on Linuxcnc 2.10pre and works great ! [attachment=56124]axis2.png[/attachment] Maybe add a readme.txt in zip with instructions to install ?? [code]Setup Instructions Main set display = axis2 in your ini sudo cp -a /home/donno/Downloads/axis2/icons/. /usr/share/axis/images sudo cp /home/donno/Downloads/axis2/axis2.tcl /usr/share/axis/tcl sudo chmod +x /home/donno/Downloads/axis2/axis2.tcl sudo cp /home/donno/Downloads/axis2/axis2 /usr/bin sudo chmod +x /usr/bin/axis2 sudo cp /home/donno/Downloads/axis2/glcanon.py /usr/lib/python3/dist-packages/rs274/ sudo chmod +x /usr/lib/python3/dist-packages/rs274/glcanon.py Linuxcnc-DEV set display = axis2 in your ini sudo cp -a /home/donno/Downloads/axis2/icons/. /home/donno/linuxcnc-dev/share/axis/images/ sudo cp /home/donno/Downloads/axis2/axis2.tcl /home/donno/linuxcnc-dev/share/axis/tcl/axis2.tcl sudo chmod +x /home/donno/linuxcnc-dev/share/axis/tcl/axis2.tcl sudo cp /home/donno/Downloads/axis2/axis2 /usr/bin sudo chmod +x /usr/bin/axis2 sudo cp /home/donno/Downloads/axis2/glcanon.py /usr/lib/python3/dist-packages/rs274/ sudo chmod +x /usr/lib/python3/dist-packages/rs274/glcanon.py where "donno" should be your username
Last edit: 1 year 4 months ago by michaeln.
- zack
- Thank you received: 47
5 months 5 days ago #346669
by zack
Replied by zack on topic Axis 2 - touchscreen version of old friend
still interested in taking a tcl touch screen version of axis further any interest?
will like to add pause routine as per 3d printers etc
The following user(s) said Thank You: Masiwood123
Time to create page: 0.444 seconds
