Can't install camview in buster
3 years 11 months ago #255930 by seuchato
I recalled doing an update this afternoon. Now, I am on
 LANG=C apt list python Listing... Done python/oldstable,now 2.7.16-1 amd64 [installed,automatic]
Could someone with a working config kindly cross check  with their version, please?
3 years 11 months ago #255932 by seuchato
same result on a different PC, so I rule hardware defects out.
3 years 11 months ago #255976 by phillc54
buster:~ $ apt list python Listing... Done python/oldstable,now 2.7.16-1 amd64 [installed,automatic]
from linuxcnc_info:
Warning: Spoiler!
3 years 11 months ago #255992 by seuchato
Phill, thanks
my output of linuxcnc_info attached. I need to finish some stuff, will campare it later
greez
chris
3 years 11 months ago #255994 by seuchato
Phill
Here's the diff
[color=#000000]diff linuxcnc_info-phillc54.txt linuxcnc_info.txt  [/color] 8,9c8,9 <                 Date: Thu 3 Nov 10:43:48 AEDT 2022 <             UTC Date: Wed 2 Nov 23:43:48 UTC 2022 --- >                 Date: Sat Nov 5 09:20:05 CET 2022 >             UTC Date: Sat Nov 5 08:20:05 UTC 2022 11c11 <               uptime: 10:43:48 up 4 min, 1 user, load average: 1.57, 0.95, 0.40 --- >               uptime: 09:20:05 up 16:31, 7 users, load average: 1.91, 1.37, 1.08 14,17c14,17 <                  pwd: /home/phill <                 USER: phill <              LOGNAME: phill <                 HOME: /home/phill --- >                  pwd: /home/cnc/linuxcnc/configs/sim >                 USER: cnc >              LOGNAME: cnc >                 HOME: /home/cnc 20c20 <             LANGUAGE: en_AU:en --- >             LANGUAGE: de_CH:de 23,25c23,25 <              DISPLAY: :0.0 <              DESKTOP: lightdm-xsession <         display size: 1680x1050 pixels (445x278 millimeters) --- >              DISPLAY: :0 >              DESKTOP: /usr/share/xsessions/plasma >         display size: 3840x2160 pixels (1016x571 millimeters) 29c29 <          nodename -n: buster --- >          nodename -n: cnc0 38,43c38,43 <              cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-22-rt-amd64 root=UUID=3f40f14d-34e4-4689-8780-6c3467194579 ro initrd=/install/initrd.gz quiet <           model name: Intel(R) Core(TM) i5-5675R CPU @ 3.10GHz <                cores: 1 <              cpu MHz: 3092.840 <              parport:   <               serial:   --- >              cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-22-rt-amd64 root=UUID=eac818d5-2e81-4b83-8807-f44a4190e973 ro initrd=/install/gtk/initrd.gz quiet acpi_osi=!Linux-Lenovo-NV-HDMI-Audio isolcpus=0 >           model name: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz >                cores: 2 >              cpu MHz: 3331.950 >              parport: 0000-0000 : parport0 0000-0000 : parport0 >               serial: 0000-0000 : serial 0000-0000 : serial 48c48 <                  git: git version 2.20.1 --- >                  git: not_in_PATH 52c52 <                glade: not_in_PATH --- >                glade: glade 3.22.1 70c70 < rc  linuxcnc            1:2.8.2      amd64        motion controller for CNC machines and robots --- > un  linuxcnc            <none>       <none>       (no description available) 72a73 > ii  linuxcnc-doc-cn     1:2.8.4      all          motion controller for CNC machines and robots (Chinese 73a75,76 > ii  linuxcnc-doc-es     1:2.8.4      all          controlador de movimiento para máquinas CNC y robots (Español). > ii  linuxcnc-doc-fr     1:2.8.4      all          motion controller for CNC machines and robots (French documentation) 77a81 >
My short analysis:
  • I guess hardware is irrelevant
  • You got git installed, me not
  • I got glade installed, you not
  • You are on lcnc 2..8.2, me seemingly no version ????
    "> un  linuxcnc            <none>       <none>       (no description available)"
    How's that possible? I AM on 2.8.4
  • => I'll try the same stuff on a fresh install, need a couple of hours, as I am not where the spare PCs are
Greez
chris
3 years 11 months ago #256051 by seuchato
Playing around with cam_align: Knocks me off my socks. How hot is that:
Taken from here: " github.com/LinuxCNC/linuxcnc/blob/master...mview_widget.py#L281 "
cmorley: I declare myself a fan of you and that super work!
Thanks a ton for this!
chris
Time to create page: 0.213 seconds
