Can't install camview in buster
3 years 11 months ago #255774 by seuchato
a) It works on 2.8.4 here without any noticeable startup delay, the "BadDrawable" messages only seem to appear during shutdown.
b) I do see these at the top of your messages, I have no idea what they are or whether they cause any issues.
# handle_includes(): <35> found #INCLUDE with no filename # handle_includes(): <36> CANNOT READ nosuchfile
Phill
a) I am on 2.8.4 too. I use debian, plasma, kde, which might be a bit exotic, but gave best latency results on my machine. I'll attach the file "1601610130.hw.txt" where you should see everything about the machine/os/etc. Note: The run was in 2020, still on 2.8.0, but the machine is really upgraded to 2.8.4 now.
greez
chris
3 years 11 months ago #255776 by seuchato
maybe it has to do with this?
linuxcnc.org/docs/devel/html/config/ini-...html#sub:ini:include
Chris
While I am trying to track these messages, I renamed the include file based "cnc0-inc.ini" epanded "cnc0-inc.ini.expanded" to "cnc0-inc.ini.expanded.ini" and started it. The error messages are gone, but the delay stays. See attached file.
So it must be something else.
greez
chris
3 years 11 months ago #255809 by phillc54
I get all the same messages as you except that I don't get this:
Waiting for component 'qtvcp_embed' to become ready.......[QTvcp][DEBUG]  Calling the handler file's initialized__ function (qtvcp:219)
I am using XFCE on a Debian Buster VM and it loads really quickly. Is it possibly a KDE thing?
3 years 11 months ago #255832 by seuchato
Phill
I'll test it later today and report back.
Greez
chris
3 years 11 months ago #255922 by seuchato
Tested it under xfce. Same thing, even worse. I am delaed about 40 secs.
I'll try to attach the output in an edit, else that @#!! will probably garble the whole post again (Grrr!).
greez
chris
3 years 11 months ago #255924 by seuchato
As you can see from attached files, it starts up, is delayed a lot and finally crashes
"TCL error in asynchronous code:
    while executing
"140563265310144check_dynamic_tabs"
    ("after" script)"
any ideas?
greez
chris
Time to create page: 0.279 seconds
