started linuxcnc and got a pthon erro, see attached screen shot and errortext below:
File "/usr/bin/qtvcp", line 377, in <module>
APP = QTVCP()
File "/usr/bin/qtvcp", line 211, in __init__
window.instance()
File "/usr/lib/python2.7/dist-packages/qtvcp/qt_makegui.py", line 178, in instance
instance = uic.loadUi(self.filename, self)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/__init__.py", line 226, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/loader.py", line 72, in loadUi
return self.parse(filename, resource_suffix, basedir)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 1021, in parse
actor(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/camview_widget.py", line 71
SyntaxError: Non-ASCII character '\xe2' in file /usr/lib/python2.7/dist-packages/qtvcp/widgets/camview_widget.py on line 71, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Guess, that's because 2.9 is based on python 3 and 2.8.3 is still on 2.7. I got:
I am not familiar with python. Thus I do not feel fit to backport stuff to 2.7 (if possible at all). So, I cannot test it under 2.8.4.
