Hi allIgot the delay down to a few seconds. While this is acceptable to me, I don't know why it decreased. That leaves a bit a bad taste and a kind of uncertanty: will it stay like that or come back to a higher delay later?For the time being, I consider this issue solved.I do have another issue though: While axis and DRO preview tabs scale nicely to the the space available, the cam_align tab does not:axis preview:
cam_align tab after resizing:
You can see, the cam_align picture is a) not expanded to the available tab camvas size b) after trying to resize with the mouse, the picture istelf is cut off.
I looked at the source code (
github.com/LinuxCNC/linuxcnc/blob/master...mview_widget.py#L281
), and indeed, the window size is hard coded:
I guess, that could be changed. I will try to change the fixed size to another value. I do write apps in C++ though and a few java thingis. As I am not familiar with python, I guess, I cannot suggest an appropriate modification. Maybe Chris Morley could?
It would be the dot an a perfect thing
greez
chris
