- Thank you received: 2181
I did commit changes to 2.9 to allow setting the rotation increment with the INI with -o rotincr=.2
I think if you use the 2.8.4 camview_widget.py but use the updated 2.9 cam_align handler, you will at least be able to set the rotation increment from the INI.
Yes it goes quick to get the hang of it, when you have read the docs. If not, you you are a bit surprised what it does when trying the mouse combinations (if you know that there are some).
So this is not really intuitive. Or maybe a help button with a question mark could be added or so.
My opinion:
- don't reset on double-click (if you want to increment fast, you reset it accidentally), do that with a button
- I wonder if you need to adjust the circle diameter and the rotation of the cross hair at the same time. I think you want either focus on an edge or a hole. So maybe switch with (radio-)buttons whether you want to change the rotation, circle diameter or zoom and then change the selected value either with mouse wheel or left/right click
- changing the increment with middle click is ok I think
- hold left + mouse wheel is not really comfortably to use (I use to scroll with the index finger)
And yes I agree, some button for touch screens would be helpful.
Off topic: You can't know it because it's a converted Cyclone 13 (not well known in Europe). I added the gennaker boom, trapeze and so on.
