Servo Spindle motor encoder Mesa 7i76e
6 years 7 months ago #160183 by Erikcnc
andypugh wrote:
Erikcnc wrote: There is a difference in the poly v belt wheels. A deviation of 5%
That will do it. Successive index pulses will have a different relationship to the spindle position, so multi-pass threading can't work.
You could probably make it work by:
1) Adjust the scaling to be as close as possible, over 30 turns of thread the error is likely to be small.
2) Use a separate index that is not related to the encoder but is from a sensor on the spindle. A hole drilled in the main spindle drive pulley, as an example.
Would a quadrature encoder work? i can do it originally with a second timing belt on the main spindle to a holder with an encoder.
Also the encoder has to handle 6500 rpm. so what type do i need?
6 years 7 months ago #160184 by blazini36
tommylight wrote: Timing belts.
I would not try tapping with a V belt.
Works quite well actually as long as it doesn't slip. I run 2:1 for tapping.
6 years 7 months ago #160189 by tommylight
Yup, exactly, but i use some expensive taps and it hurts a lot when they do brake.
Anyway, for now i have no machine that i can tap with, so a cordless drill (or 8 of them) does the job, with the occasional blackout when they do brake. :)
6 years 7 months ago - 6 years 7 months ago #160194 by blazini36
Cordless drill is tough to keep straight, which leads to more broken taps than a properly setup mill would even with a "V" belt.
If we're talking about a typical oldschool V belt, well they aren't much good for anything IMO. A tiny microV works way better than you would probably think. I've never actually slipped this belt, I've crashed the spindle hard enough to have the pulley yank off the spindle shaft, but that would happen with a Vbelt just the same. This is just a 10-32 @300rpms but I've done upto 5/16". Never tested larger on this setup, not sure what 1hp @ 2:1 can handle.
Last edit: 6 years 7 months ago by blazini36.
6 years 7 months ago #160210 by tommylight
Subscribed !
Nice. Thank you.
6 years 7 months ago - 6 years 7 months ago #160743 by Erikcnc
impressive!
So could you explain how its setup in linux?
and what are u using from the servo driver outputs and what not?
The sensor next to the spindle what type of proximity switch is it?
Last edit: 6 years 7 months ago by Erikcnc.
Time to create page: 0.379 seconds
