Servo Spindle motor encoder Mesa 7i76e
6 years 6 months ago #165834 by andypugh
Erikcnc wrote: near.0.in1 is then 16.66667
near.0.in2 is fluctuating around that same value.
And what is near.0.out doing?
And does motion.spindle-revs _increase_ by 1 for each forward rotation of the spindle?
6 years 6 months ago #165841 by Erikcnc
near.0.out
is true when spindle is not rotating. is false when spindle is on
motion.spindle-revs
every one rotation its counts 1.
6 years 6 months ago #165854 by andypugh
near.0.out should go true (at 1000 rpm) if:
in1 > 11 AND in1 < 25
OR
in1 > 13 AND in1 < 19
So, for the numbers given, near.0.out really should be changing value.
The following user(s) said Thank You: Erikcnc
6 years 6 months ago #165971 by Erikcnc
andypugh wrote: near.0.out should go true (at 1000 rpm) if:
OR
i found something thoug.
i changed
net spindle-vel-cmd-rps => near.0.in1
to
net spindle-vel-cmd-rps-abs => near.0.in1
at M4 (what i use for normal turning (slandbed)) i got spindle at speed on true (green led)
M3 does not get on true.
to be fair, have no idea what abs does.
if i ajust
net spindle-fb-rpm => near.0.in2
to
net spindle-fb-rpm-abs => near.0.in2
every direction is false again.
maybe ringing a bel?
6 years 6 months ago #165978 by andypugh
When you said that in1 and in2 were "about the same value" did you possibly mean "except for one being positive and one being negative"
I suspect that if you used both the -abs signals then it would work.
"abs" means "absolute value", without the sign.
6 years 6 months ago - 6 years 6 months ago #165987 by Erikcnc
I'm sorry, things getting weirder and weirder.
I changed something, but before that i checkt the near pin again in halshow
M3 1000 rpm
near.0.out false near.0.in1 16.66667 near.0.in2 -16.68*** fluctuating
M4 1000 rpm
near.0.out false near.0.in1 16.66667 near.0.in2 16.68*** fluctuating
So what did i changed
Hal
counter-mode set to 0 to quadrature mode
INI
Encoder is A+ B+ and Z+ 1024 P/R
www.antratek.com/rotary-encoder-1024-p-r-quadrature
Encoder_scale = 4096
Output_scale = 5700 (because of the drive wheel diameter difference 5%)
Standard i got 1000 rpm in gmoccapy.
M3 1000 rpm gets true
M4 is -1000 rpm gets also true.
Now, at 2000 rpm...spindle goes to around 500 in both directions.
Same counds for 1200 rpm.
But, if i touch the slide bar to 50% and carfully go to 100%...i got the right rpm....
What is going on here?
Sorry i i'm doing things 'out of the box'....
I will attach new hal and ini files.
File Name: EMCOTURN22...4-28.hal
File Size:11.43 KB
File Name: EMCOTURN220.doc
File Size:3.59 KB
Last edit: 6 years 6 months ago by Erikcnc.
Time to create page: 0.448 seconds
