Servo Spindle motor encoder Mesa 7i76e
6 years 8 months ago #158893 by PCW
975 is a very odd number so I suspect something is still wrong
The 7I76E encoder jumpering must match the electrical interface on the encoder
Differential encoder interfaces will have 6 signals instead of 3:
Differential:
A, /A B, /B Z, /Z
TTL/single ended:
A,B,Z
The following user(s) said Thank You: Erikcnc
6 years 8 months ago #158906 by Erikcnc
PCW wrote: 975 is a very odd number so I suspect something is still wrong
Differential:
A, /A B, /B Z, /Z
TTL/single ended:
A,B,Z
oke, well that confirms that the jumpers are right.
i set the encoder scale in my .ini file back to 1024. in program run its wait for spindle reach.
this is really weird what cause this.
6 years 8 months ago #158909 by PCW
To check if its a bad encoder, you could rotate at a constant speed and plot the
encoder velocity with HALScope. A bad /dirty encoder wheel will show up as a repeating dip in velocity
6 years 7 months ago #158977 by Erikcnc
PCW wrote: To check if its a bad encoder, you could rotate at a constant speed and plot the
Found it!
Nothing in linuxcnc or drivers.
There is a difference in the poly v belt wheels. A deviation of 5%
I get the same offset in the drive. So i was questioning my self why also the drive counts where off.
Now, I might add a encoder on the spindle its self (as it was original but one puls).
I would like to have also a quadrature encoder on it, so i can also ridgit tap.
Or, i replace the v belt wheels to timing belt. Might be more work, but then i can use the servo motor as i intended.
Any suggestions?
6 years 7 months ago #159018 by tommylight
Timing belts.
I would not try tapping with a V belt.
6 years 7 months ago #159197 by andypugh
Erikcnc wrote: There is a difference in the poly v belt wheels. A deviation of 5%
That will do it. Successive index pulses will have a different relationship to the spindle position, so multi-pass threading can't work.
You could probably make it work by:
1) Adjust the scaling to be as close as possible, over 30 turns of thread the error is likely to be small.
2) Use a separate index that is not related to the encoder but is from a sensor on the spindle. A hole drilled in the main spindle drive pulley, as an example.
Time to create page: 0.079 seconds
