andypugh wrote: Your HAL
Code:net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd-rpm <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs ... net spindle-vel-cmd-rps => near.0.in1 net spindle-vel-fb-rps => near.0.in2 net spindle-at-speed motion.spindle-at-speed <= near.0.outAre you actually controlling spindle speed from G-code?
Does Halmeter show the spindle speed on the motion.spindle-speed-out-rps pin?
Everything looks like it should work.
also at motion.spindle-speed-out-rps nothing.
Is the spindle controlled by M3 / M4 and S?
I am failing to see how the spindle can be controlled by the motion.spindle pins but for there to be no output on one of those pins.
Which version of LinuxCNC are you using?
Erikcnc wrote: im using 2.4.17
Some of the spindle speed pins have changed since v2.4 (2011?) Are you sure that you are usiong that version? I would expect there to be an error if you were adding pins to a net that don't exist. linuxcnc.org/docs/2.4/html/man/man9/motion.9.html
I am beginning to wonder if you are running the HAL file that you think you are.
Are you really saying that motion.spindle-speed-out has a value, but motion.spindle-speed-out-rps does not? That seems almost impossible.
