Pimping the mini-lathe
11 Oct 2020 08:29 #185711 by my1987toyota
Replied by my1987toyota on topic Pimping the mini-lathe
looks like I am going to be binge watching this whole series and taking notes for my upcoming G0602 build .
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Oct 2020 07:15 #185822 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
I have some fitted soft jaw copper shims like that for my four jaw, but didn't have any for the three jaw.
I am sure that the G0602 is significantly more rigid than the mini lathe.
Mark
The following user(s) said Thank You: my1987toyota
12 Oct 2020 07:46 #185828 by andypugh
Replied by andypugh on topic Pimping the mini-lathe
Just playing around, what is the syntax to use natural constants like Pi or "e" in gcode?
#<103>=[pi/e]
Sadly, I think it is
#103 = 1.155727349790922
  • RotarySMP
  • Platinum Member
  • Platinum Member
12 Oct 2020 08:42 #185837 by RotarySMP
Yep, at least I learned you can do named variables.
;Weird thread
;Why? Because a CNC lathe can!
;Tapered 3 start RH thread 23/57"OD  x Pi TPcm, 11/7 Chi long, with a 23/19e taper angle.
;Z0 is end of stock.
#<_pi> = 3.14159
#<_e>  = 2.71828
#<_chi>= 30.3
#<_starts>           = 3
#<_OD>               = [23/57*25.4]
#<_Z_LeadIn>         = [#<_pi>*4]
#<_Pitch>            = [#<_pi>]
#<_ThreadDepth>      = [#<_pi> /3 ]
#<_ThreadLength>     =-[#<_chi>*11/7]
#<_TaperAngle>       = [23/19*#<_e>]
#<_NumThreadPasses>  = ROUND[#<_ThreadDepth>/0.1]
#<_SmallDia>         = [#<_OD> - [SIN[#<_TaperAngle>*2]] *[#<_Z_LeadIn> + ABS[ #<_ThreadLength>]]]
#<_DiaChange>        = [#<_OD> - #<_SmallDia>]
#<_NumCuttingPasses> = ROUND[#<_DiaChange>]
#<_stockDia> = 20
#<_stockOff> = [#<_stockDia>  - #<_OD>    ]
#<_NumsizePasses> = ROUND[#<_stockOff>]
#<_feedrate>         = 150
#<_Speed>            = 1000
#1                   = 1 ; Index start passes
#2                   = 1 ; Index threading passes
#3                   = 1 ; Index cutting passes
#4                  = 1 ;Index resize
O110 sub ;Cut taper
	O110 while [#3 LE #<_NumCuttingPasses>]
		G0 Z[#<_Z_LeadIn>]
	   	   X[#<_SmallDia> + [[#<_NumCuttingPasses> - #3] * [#<_DiaChange> / #<_NumCuttingPasses> ]]]
		G01 Z[#<_ThreadLength>] X[#<_OD> + [[#<_NumCuttingPasses> - #3] * [#<_DiaChange> / #<_NumCuttingPasses> ]]] F#<_Feedrate>
		G0 X[#<_OD> + #<_DiaChange>]
		#3 = [#3 +1]
	O110 Endwhile
O110 endsub
O111 sub ; Cut Thread
	O100 while [#1 LE #<_starts>]
		O101 while [#2 LE#<_NumThreadPasses>]
			G0 Z[#<_Z_LeadIn> + [[#1 - 1] * [#<_Pitch>/#<_starts>]]]
	   	   	   X[#<_SmallDia> - [[#2]*[#<_ThreadDepth> / #<_NumThreadPasses> ]]]
			G33 Z[#<_ThreadLength>]  X[#<_OD> - [[#2 - 1] * [#<_ThreadDepth>/ #<_NumThreadPasses> ]]] K#<_Pitch>
        		#2 = [#2 + 1]
		O101 endwhile
		M5
		G4 P2
		M3
		G4 P2
		#2 =1
		#1 = [#1 +1]
                #<_SmallDia> = [#<_SmallDia> - [SIN[#<_TaperAngle>]*[#1 -1] * [#<_Pitch>/#<_starts>]]]
	O100 EndWhile
O111 endsub
O120 Sub ; resize stock
      O121 while [ #4 LE #<_NumsizePasses>]
               M3
               G0 X [#<_stockDia> +1]
               G0 Z1
               G01 X [#<_stockDia> - [#<_stockOff> / #<_NumsizePasses> * #4] ]   F #<_feedrate>
               g01 Z [#<_ThreadLength>]
               #4 = [#4+1]
         O121 endwhile
O120 endsub
;Main
G18 G21 G40 G49 G54 G80 G94 G90 G7
F#<_Feedrate> S#<_Speed>
M3
G4 P2
O120 call
O110 call
M5
G4 P2
M3
O111 call
M9 M5
M2
14 Oct 2020 17:27 #186135 by my1987toyota
Mark
true.
I know it's still a little early but how is the computer working out for your mini lathe build ? would you recommend it?
  • RotarySMP
  • Platinum Member
  • Platinum Member
16 Oct 2020 11:24 #186295 by RotarySMP
It was a pita to set up (but that was probably just personal incompetence). It boots pretty slowly. It runs fine with the Mesa 7i97, I have not had any stablity issues with it. Its internal WiFi widget was automatic configured by Mint, so that was nice benefit, as I could easily häng it on my WiFi network.
Mark
16 Oct 2020 18:31 #186332 by my1987toyota
If you don't mind RotarySMP I have another question for you . How do you like the omron rotary encoder
would you recommend using it?
  • RotarySMP
  • Platinum Member
  • Platinum Member
17 Oct 2020 02:15 #186344 by RotarySMP
It was easy to hook up and works flawlessly so far.
  • RotarySMP
  • Platinum Member
  • Platinum Member
25 Oct 2020 06:37 #187185 by RotarySMP
I just uploaded E33...
Enjoy
Mark
The following user(s) said Thank You: phillc54, arvidb, tommylight, Gerald, my1987toyota
  • RotarySMP
  • Platinum Member
  • Platinum Member
01 Nov 2020 05:04 #187998 by RotarySMP
I just uploaded the next episode, covering the CNC control panel...
Enjoy,
Mark
The following user(s) said Thank You: phillc54, arvidb, tommylight, Clive S, rodw, my1987toyota
Moderators: piasdom
Time to create page: 0.126 seconds
