Schaublin 125-CNC retrofit.
5 years 8 months ago #199706 by Aciera
Replied by Aciera on topic Schaublin 125-CNC retrofit.
Judging from your photo I would say it's the same as these (Resolvers off of an ebay sale):
5 years 8 months ago #199707 by db1981
Replied by db1981 on topic Schaublin 125-CNC retrofit.
take a look at the granity argon drives. they are able to control brushed and brushless dc with resolvers. And have the advantage of direct 230V AC Power input.
5 years 8 months ago #199711 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Hmmm, that is a tasty solution. Keep the motor and their cables, but only need two drivers the size of paperbacks powered by single phase AC. They are pretty pricey, at €500 including VAT, but would save me a bunch of time mucking around with mounting replacement motors. WIth a hobby, is time save = money a thing?
Mrk
5 years 8 months ago #199714 by db1981
hmm, i'm not shure if this resolver will work with todays servo drives.
There is less information in the web about this types. in other boards is written that this old ones have 2 input coils and one output coil, and were driven with an sin and cos signal.
todays resolvers have only on input, and coils for sin/cos output.
don't know if they could be driven backwards, I'm not old enough for such electro/magnetics stuff :-)
5 years 8 months ago - 5 years 8 months ago #199716 by Aciera
You might actually want to inquire whether the 7i49 can actually handle this kind of "3-phase" resolver.
[edit]
I guess the proper term is "synchro resolver" or just "synchro"
Last edit: 5 years 8 months ago by Aciera.
5 years 8 months ago #199737 by tommylight
Replied by tommylight on topic Schaublin 125-CNC retrofit.
I have used Argon drives on a Hurco retrofit, but not sure they had resolver support. It is mentioned that they will in the future, although all that is a bit foggy by now since that was several years back.
They are nice drives, but do have a very irritating issue, namely they use RS485 at very high speeds to program the drives and that link fails as soon as you enable the drive, so use shielded RJ45/STP cable, otherwise ..... :)
Time to create page: 0.239 seconds
