- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
5 years 8 months ago #200528
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Good point. Those huge cast aluminum motor housings might have a data plate underneath. I didn't think to look. Or those are just huge motor covers, and the motors are inside
Overkill was a thing with this lathe.
Mark.
Mark.
- db1981
- Thank you received: 276
5 years 8 months ago #200683
by db1981
Replied by db1981 on topic Schaublin 125-CNC retrofit.
@Anfänger
if you need some information, just ask ... my wife got all type plates re-readable
- anfänger
- Thank you received: 267
5 years 8 months ago #200687
by anfänger
Replied by anfänger on topic Schaublin 125-CNC retrofit.
@db1981 Thanks, but I guess I have figured everything out which stays and the rest I switched to something new, where I know the parameters. But do you have a thread or pictures somewhere? I would love to see your machine.
- RotarySMP
5 years 8 months ago #200693
by RotarySMP
Is there a technical reason to prefer setp/dir vs analog control when driving AC servos?
If I switch to modern AC servos which support either step/dir or +/-10V analog control input, and add linear encoder feed back, I have the choice between the Mesa 7i95 or the 7i97. What are the advantages / disavantages of one over the other?
Actually, if I find AC servo sets which pass their encoder signal back to the controller, I could do closed loop back to LinuxCNC and not have the headache of finding a space to mount a cross slide linear encoder.
Mark
Mark
- anfänger
5 years 8 months ago - 5 years 8 months ago #200697
by anfänger
I don’t know, but I prefer +-10V analog control.
The reason is: I have already done it with the Sinumerik
The lichuan servos and drives I use pass an encoder signal to the control and can be driven step/Dir and +-10V Most prefer Step/Dir to avoid tuning, but I found it not to hard (But the drivers were already tuned) I will see later if I regret it. And you can tune without the servos actual attached to the machine.
Last edit: 5 years 8 months ago by anfänger.
- RotarySMP
5 years 8 months ago #200698
by RotarySMP
I already used analog on the Maho, and had to tune the servos and after a bit of dicking around found a set up which seems fine. I am a big overwhelmed with all the different options right now, but appreciate the inputs.
Mark
Mark
Time to create page: 0.282 seconds
