Schaublin 125-CNC retrofit.
5 years 7 months ago #201292 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Andy started a discussion on the Mesa Card choise in the YT comment section, but I would like to record my thoughts on it here:
I will do a control panel up on the stalk like Schaublin did it. The PC will be housed there. So it will be Cat 6 down to the electrical cabinet to a 7i9x
I have two of Peter's (Talla83) RS422 - SS adapter cards made. These will take to place of a 7i74 next to the 7i9x.
I will need more than 6 Outputs, so I will need a 7i84. I'll also use a 7i73 back up in the user control panel.
I also have some of Peters PCB's to make up two TsHw boards, which I can use as Encoder interface boards with Cat 6 back to the SS adapter cards.
The bit I am stuck on is which 7i9x to get? I am pretty sure it will be an analog servo system, so a 7i97 would work, but that is the biggest and most expensive card, which seems like overkill for two Servos and 3 encoders.
The 7i98 or 7i94 would be cool, but I don't see a DB25 daughter card which supports servos. The 7i33 needs a 50pin FPGA Card right?
I guess I could do 7i93 / 7i33TA and then run all the SS stuff though the extr 50 expansion slot right?
Mark
5 years 7 months ago #201293 by db1981
Replied by db1981 on topic Schaublin 125-CNC retrofit.
J Green
Do you know if the Stmbl servo drive design has overcome that one IC being not available anymore ? Or if there is continuing effort in the Stmbl servo drive ? Hope there is as I thought it was a very useful - configurable servo drive .
I don't know details from this project, but there is actually work progress....
github.com/rene-dev/stmbl
The following user(s) said Thank You: J Green
5 years 7 months ago - 5 years 7 months ago #201296 by J Green
Replied by J Green on topic Schaublin 125-CNC retrofit.
Mark
Thank You ----for the update about your Schaublin lathe , you have been busy .
Relays - pneumatic valves - contactors for motors
Wonder if ZincBoy ( Retrofit of a Hitachi-Seike VK45 mill ) would provide details of his solid-state relay Bd.?
Would a 7i77D or 7i83 be worth considering ? Trying to attach a YouTube thing about lost foam casting that shows a cheap vacuum accessory .
Bob
Last edit: 5 years 7 months ago by J Green. Reason: Add 7i77D thought
5 years 7 months ago #201297 by PCW
Replied by PCW on topic Schaublin 125-CNC retrofit.
Unfortunately we don't have any low channel count analog 25 pin daughtercards
Probably the best would be a 7I94+ 7I77 combination
5 years 7 months ago #201299 by andypugh
Replied by andypugh on topic Schaublin 125-CNC retrofit.
RotarySMP wrote: The 7i98 or 7i94 would be cool, but I don't see a DB25 daughter card which supports servos. The 7i33 needs a 50pin FPGA Card right?
50-pin + smart-serial can work well if you have a PCI PCI-e slot. The 5i24 / 6i24 are a lot of pins for the money, and are what run my lathe.
(My lathe is 6i24 7i49 7i44 7i84 7i73 2x8i20 and has a whole 50-pin connector free.)
5 years 7 months ago #201300 by andypugh
PCW wrote: Unfortunately we don't have any low channel count analog 25 pin daughtercards
How about the 7i83?
Time to create page: 2.430 seconds
